    Black screen with MMM Pir sensor after update
    13 Posts 6 Posters 4.3k Views 6 Watching
      satsatt @rabbit83ka
      @rabbit83ka Thank’s that worked for me too.
      • U Offline
        uatuba @sdetweil
        @sdetweil This does not work for me. I run npm install, and I get:
        > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
        > electron-rebuild -e ../../node_modules/electron
        ✖ Rebuild Failed
        An unhandled error occurred inside electron-rebuild
        make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
          CXX(target) Release/obj.target/epoll/src/epoll.o
        ../src/epoll.cc: In static member function ‘static void Epoll::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:
        ../src/epoll.cc:163:39: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
           constructor.Reset(ctor->GetFunction());
        In file included from ../src/epoll.cc:11:0:
        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:5891:46: note: candidate: v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)
           V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:5891:46: note:   candidate expects 1 argument, 0 provided
        ../src/epoll.cc:165:23: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
        At global scope:
        cc1plus: warning: unrecognized command line option ‘-Wno-cast-function-type’
        epoll.target.mk:109: recipe for target 'Release/obj.target/epoll/src/epoll.o' failed
        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
        make: *** [Release/obj.target/epoll/src/epoll.o] Error 1
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/build.js:194:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 4.19.66-v7+
        gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source"
        gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
        gyp ERR! node -v v10.18.0
        gyp ERR! node-gyp -v v6.1.0
        gyp ERR! not ok
        Failed with exit code: 1
        Error: make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
        At global scope:
        gyp ERR! not ok
            at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/spawn-rx/lib/src/index.js:267:84)
            at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:205:16)
            at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:156:26)
            at Subscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
            at Subscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
            at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
            at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
            at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/spawn-rx/lib/src/index.js:242:65)
            at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:143:22)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 255
        npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron`
        npm ERR! Exit status 255
        npm ERR!
        npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script.
        npm ERR!     /home/pi/.npm/_logs/2020-04-12T03_38_34_229Z-debug.log
        Obviously rebuild does the same. I’ve deleted the module and reinstalled it. Any ideas?
          sdetweil @uatuba
          @uatuba this is a tricky module, very sensitive to the runtime environment… breaks every update…
          other have had success with doing a fresh git clone and npm install.
          I am not the module author, so I don’t know exactly whats going on
