    Black screen with MMM Pir sensor after update
    13 Posts 6 Posters 4.3k Views 6 Watching
    • J Online
      JoeFranz
      With the Pir sensor module, I have a black screen after starting. Have tried the following so far:
      cd ~ / MagicMirror
      npm install electron rebuild
      node_modules / .bin / electron-rebuild
      And then:
      npm rebuild or npm install
      for the pir sensor
      The mistake remains anyway, someone an idea?
      Greetings Jörg
        rabbit83ka
        I have the same error. Atteached the console output. Logfile can be found here.
        An unhandled error occurred inside electron-rebuild
        Could not detect abi for version 6.1.7 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
        Error: Could not detect abi for version 6.1.7 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
            at Object.getAbi (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-abi/index.js:30:9)
            at new Rebuilder (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:122:28)
            at rebuildWithOptions (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:393:23)
            at Object.doRebuild [as rebuild] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/rebuild.js:400:16)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/cli.js:115:33)
            at Generator.next (<anonymous>)
            at fulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/src/cli.js:5:58)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 255
        npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron`
        npm ERR! Exit status 255
        npm ERR!
        npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script.
        npm ERR!     /home/pi/.npm/_logs/2020-04-02T08_25_32_202Z-debug.log
        processing complete for module MMM-PIR-Sensor
          sdetweil @rabbit83ka
          @rabbit83ka said in Black screen with MMM Pir sensor after update:
          Updating “node-abi” might help solve this issue
          delete package-lock.json in the MMM-Pir-Sensor folder,
          run npm install there
          then maybe also have to do electron-rebuild again
          • J Online
            JoeFranz
            It works! Thank you :grinning_face:
              sdetweil @JoeFranz
              @JoeFranz did u have to electron-rebuild?
              U 1 Reply Last reply Reply Quote 0
              • J Online
                JoeFranz
                @sdetweil yes
                  sdetweil @JoeFranz
                  @JoeFranz thanks
                    rabbit83ka @sdetweil
                    @sdetweil Hi Sam, I deleted the package-lock.json, after that npm install still fails with the same error message. npm install electron rebuild also doesn’t help…
                    I wiped the module folder and reinstalled it from github, now it works.
                    S S 2 Replies Last reply Reply Quote 0
                      @rabbit83ka cool. thx for feedback
                      so, npm install after clone works…
                      must be the package-lock.json file (it recorded what it did last time)
                        Snake16547
                        Hey,
                        had the same problem with my pir sensor module and I could fix it with the help from you guys BUT now i loaded module but the monitor doesn’t shut down. Commands over ssh works fine. I did a fresh install only for the pir sensor module to get it working.
