    Black screen with MMM Pir sensor after update
    13 Posts 6 Posters 4.4k Views 6 Watching
      sdetweil @rabbit83ka
      @rabbit83ka said in Black screen with MMM Pir sensor after update:
      Updating “node-abi” might help solve this issue
      delete package-lock.json in the MMM-Pir-Sensor folder,
      run npm install there
      then maybe also have to do electron-rebuild again
        JoeFranz
        It works! Thank you :grinning_face:
          sdetweil @JoeFranz
          @JoeFranz did u have to electron-rebuild?
          U 1 Reply Last reply Reply Quote 0
            JoeFranz
            @sdetweil yes
              sdetweil @JoeFranz
              @JoeFranz thanks
                rabbit83ka @sdetweil
                @sdetweil Hi Sam, I deleted the package-lock.json, after that npm install still fails with the same error message. npm install electron rebuild also doesn’t help…
                I wiped the module folder and reinstalled it from github, now it works.
                S S 2 Replies Last reply Reply Quote 0
                  @rabbit83ka cool. thx for feedback
                  so, npm install after clone works…
                  must be the package-lock.json file (it recorded what it did last time)
                    Snake16547
                    Hey,
                    had the same problem with my pir sensor module and I could fix it with the help from you guys BUT now i loaded module but the monitor doesn’t shut down. Commands over ssh works fine. I did a fresh install only for the pir sensor module to get it working.
                      satsatt @rabbit83ka
                      @rabbit83ka Thank’s that worked for me too.
                      • U Offline
                        uatuba @sdetweil
                        @sdetweil This does not work for me. I run npm install, and I get:
                        > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
                        > electron-rebuild -e ../../node_modules/electron
                        ✖ Rebuild Failed
                        An unhandled error occurred inside electron-rebuild
                        make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                          CXX(target) Release/obj.target/epoll/src/epoll.o
                        ../src/epoll.cc: In static member function ‘static void Epoll::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:
                        ../src/epoll.cc:163:39: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
                           constructor.Reset(ctor->GetFunction());
                        In file included from ../src/epoll.cc:11:0:
                        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:5891:46: note: candidate: v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)
                           V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
                        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:5891:46: note:   candidate expects 1 argument, 0 provided
                        ../src/epoll.cc:165:23: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
                        At global scope:
                        cc1plus: warning: unrecognized command line option ‘-Wno-cast-function-type’
                        epoll.target.mk:109: recipe for target 'Release/obj.target/epoll/src/epoll.o' failed
                        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                        make: *** [Release/obj.target/epoll/src/epoll.o] Error 1
                        gyp ERR! build error
                        gyp ERR! stack Error: `make` failed with exit code: 2
                        gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/node-gyp/lib/build.js:194:23)
                        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                        gyp ERR! System Linux 4.19.66-v7+
                        gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source"
                        gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                        gyp ERR! node -v v10.18.0
                        gyp ERR! node-gyp -v v6.1.0
                        gyp ERR! not ok
                        Failed with exit code: 1
                        Error: make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                        At global scope:
                        gyp ERR! not ok
                            at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/spawn-rx/lib/src/index.js:267:84)
                            at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:205:16)
                            at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:156:26)
                            at Subscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
                            at Subscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
                            at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:92:26)
                            at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:72:18)
                            at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/spawn-rx/lib/src/index.js:242:65)
                            at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/rxjs/internal/Subscriber.js:143:22)
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 255
                        npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e ../../node_modules/electron`
                        npm ERR! Exit status 255
                        npm ERR!
                        npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script.
                        npm ERR!     /home/pi/.npm/_logs/2020-04-12T03_38_34_229Z-debug.log
                        Obviously rebuild does the same. I’ve deleted the module and reinstalled it. Any ideas?
