    A number of them rlly...
    16 Posts 3 Posters 5.0k Views 2 Watching
      Mahieedaboss
      SO,
      I am a relatively new programmer. I am on a mac mini. I am doing a manual installation. My first problem was with the Magic Mirror section. So far I have
      Download the stable version of Node.js: https://nodejs.org/en/
      Clone the latest MagicMirror code from: https://github.com/MichMich/MagicMirror
      Navigate inside the MagicMirror folder
      cd MagicMirror
      Install MagicMirror dependencies
      sudo npm install
      On the youtube walkthrough, the next step is npm start and when he does it, some text starts up on electron. For me, I start up Electron but all I see is my cursor and a black background. The command says verify it starts so have I done something wrong or not??
      Secondly, I do the following:
      Verify it starts
      npm start
      Navigate out of the MagicMirror folder
      cd …
      Clone this repository (AI Smart Mirror)
      git clone git@github.com:HackerHouseYT/AI-Smart-Mirror.git
      Copy the folders in AI-Smart-Mirror/magic_mirror to MagicMirror/modules
      Copy the config.js file in AI-Smart-Mirror/magic_mirror to MagicMirror/config
      AI
      Make sure Ruby is installed: https://www.ruby-lang.org/en/documentation/installation/
      Install Homebrew: http://brew.sh/
      Navigate to the AI-Smart-Mirror folder
      cd AI-Smart-Mirror
      Install ffmpeg
      brew install ffmpeg
      I have been successful up to here but then the next instruction is:
      Use setup.sh to create a virtual environment and install dependencies
      sudo ./setup.sh
      When I enter this, the following text appears
      Password:
      ./setup.sh: line 3: pip: command not found
      ./setup.sh: line 4: virtualenv: command not found
      ./setup.sh: line 5: ./hhsmartmirror/bin/activate: No such file or directory
      ./setup.sh: line 6: pip: command not found
      ./setup.sh: line 7: pip: command not found
      What do I do?
        sdetweil @Mahieedaboss
        @Mahieedaboss for MagicMirror use my script…
        see instructions here
        it works on mac too
        throw away the current magic mirror folder first…
        the other stuff, can’t help looks likes it old
          Mahieedaboss
          What do you mean by throw away
          I am a real beginner
            @Mahieedaboss
            looks like pip is not installed…
            and virtual env
            https://stackoverflow.com/questions/39964635/error-virtualenv-command-not-found-but-install-location-is-in-pythonpath
            google is your friend
              @Mahieedaboss said in A number of them rlly...:
              if you don’t know the command line commands
              how would u erase/delete/throw away a file or folder on a mac?
              use the finder to locate the folder and drop it in the trashcan
                Mahieedaboss
                Pip??
                Virtual env??
                GOOGLE??? (jk)
                but seriously, pip, virtual env, was this in the installation document??
                  @Mahieedaboss you reported
                  so, I searched on google for those strings… and came up with the link I posted
                  were they in the document, uh… no, because there has been some change in the last THREE YEARS since that repo was updated… my my how is THAT possible?!.. lol
                  the ONE skill EVERYONE needs in an opensource env, is the ability to search for resolutions of undocumented stuff…
                  it is assumed that everything will break shortly… cause there are no commitments to forward compatibility anymore…
                    Mahieedaboss @sdetweil
                    SO
                    I rm -r the MagicMirror/ and AI-Smart-Mirror. I installed the installation script you said. I think it was successful because there was a new directory named Magic Mirror. The last line was this
                    \e[92mWe’re ready! Run \e[1m\e[97mpm2 start MagicMirror\e[0m\e[92m from the ~/MagicMirror directory to start your MagicMirror.\e[0m
                    I have a feeling it is telling me to do something. But what!!!
                    Please help.
                    P.S What time do you stay up till because this may take some time -_- :)
                      So is this all a waste of time? This project?
                        so, you need to open a terminal window
                        then change to the users ~, MagicMirror folder MagicMirror, like this cd ~/MagicMirror
                        once there, you will need to type the command
                        npm start
                        and then hit enter
                        your next post… this project a waste of time? no idea… its old… don’t know what it did, don’t know if it will still work, or can be made to work…
                        I know I spent some time working on the aiclient with someone else a while back (many months)
                        I don’t remember the outcome
                          @Mahieedaboss I am US central time… now just after 3pm
                            Hey so I entered and then electron came up with out any text, just black w/ a cursor.
                            Also, is there a similar AI project that is more worthwhile??
                              Oh good, GMT 21 15
                                Mahieedaboss
                                S lavolp3L 2 Replies Last reply Reply Quote 0
                                  (that is called the black screen, usually cause of some error in a module)
                                  before making any changes from the rest of the script?
                                  roll the mouse up to the top left of the screen, you shoudl get a title bar, with two buttons, red and green,
                                  press green, then the middle orange minimize button,
                                  there should be messages in the terminal window… what are the last 10 messages>
                                  ai , sorry, no idea…
                                  • lavolp3L Offline
                                    lavolp3 Module Developer @Mahieedaboss
                                    @Mahieedaboss
                                    HA!
                                    This is the most worthwhile…
                                    You’re already there.
                                    Deal with it.
                                    Embrace it.
                                    How to troubleshoot modules
                                    MMM-soccer v2, MMM-AVStock
