MMM-Remote-Control API Questions
17 Posts 3 Posters 4.0k Views 3 Watching
    sgarg15 @sdetweil
    @sdetweil Also how do i make it so that the python file is always running?
      sdetweil @sgarg15
      @sgarg15 that was the example of running a little js app on the command line node js_filename
      The exact code here doesn’t help you, but the prior code I posted is what u want to try. Altho I don’t know how u will hook it to the sensors on your pc
      S 1 Reply Last reply Apr 19, 2020, 11:24 PM Reply Quote 0
        @sgarg15 your python PGM has to loop somehow. I don’t do python
          sgarg15
          @sdetweil so, i have my python script running in the background, and in my nodeHelper.js i would have
          import {PythonShell} from 'python-shell';
          let pyshell = new PythonShell('Swiping.py');  // < --- whatever your script name, in the module folder
          // the .on handler gets called each time the pythin script writes a message to stdout
          pyshell.on('message', function (message) {
            // received a message sent from the Python script (a simple "print" statement)
            console.log(message);
            // send info up to modulename.js
            this.sendSocketNotification("movement", message)
          could you explain what movement and message mean in the sendSocketNotification?
          • E Offline
            ertopps Banned
            If you could help me achieve this, or give me some info that could help me do this i would really appreciate it
            S 1 Reply Last reply Apr 28, 2020, 11:39 AM Reply Quote 0
              sdetweil @ertopps
              @ertopps do what?
              • E Offline
                ertopps Banned
                I am stuck due to similar issues. And now I need some professional developers with Python knowledge and good programming skills. I am from the US, check this out. And you need to be able during my working hours, it will be a great advantage for fruitful cooperation. Send me a message to my private box for more details. I do hope to find someone here with your assistance.
