    MMM-Remote-Control API Questions
    17 Posts 3 Posters 5.7k Views 3 Watching
      sdetweil @sgarg15
      @sgarg15 so, you need a node_helper for the python script to send the notice to(as it can launch the python script and read the messages) and then the node helper can send the notification up to its modulename.js, which can then send the notification.
      lots of modules work this way, PIR
      MMM-Swipe does this exact thing, which is what I think u want to use
      fork it, change the name, and modify the node_helper to launch your python script and accept your python messages
        sgarg15 @sdetweil
        @sdetweil If possible could you please give me an example of how i would do it, i dont know much about js. and i looked at the MMM-Swipe but i couldnt understand much
          sdetweil @sgarg15
          @sgarg15 swipe isn’t a good example after all, uses a library which hides all that… nor PIR…
          your python script needs to run forever and put out messages for each movement it sees…
          then you use the nodejs Python_Shell library to launch it
          import {PythonShell} from 'python-shell';
          let pyshell = new PythonShell('my_script.py');  // < --- whatever your script name, in the module folder
          // the .on handler gets called each time the pythin script writes a message to stdout
          pyshell.on('message', function (message) {
            // received a message sent from the Python script (a simple "print" statement)
            console.log(message);
            // send info up to modulename.js
            this.sendSocketNotification("movement", message)
            sgarg15 @sdetweil
            @sdetweil This may be a stupid question, but is there any way i can test this on my laptop, without the raspberry pi?
              sdetweil @sgarg15
              @sgarg15 of course. See my comments in .txt file include
              https://forum.magicmirror.builders/topic/555/txt-file-include/57
              Not the actual node_helper but the code inside. Of course u can install mm on your PC as well
              S 3 Replies Last reply Reply Quote 0
                sgarg15 @sdetweil
                  sgarg15 @sdetweil
                  var dataFile=["Archer S01E02Someshow.tv",
                  "Archer S01E03Someshow .tv",
                  "Archer S01e02Someshow .tv",
                  "Archer S01E04Someshow .tv",
                  "Archer S01E05someshow .tv",
                  "Archer s01E02Someshow .tv",
                  "Archer S01E09Someshow .tv",
                  var counter1=10
                                      if(dataFile){
                                          var output_list= [];
                                          // should make this a config variable by adding to module defaults
                                         // then would be this.config.counter
                                         // get display limit, 10 if not specified in defaults
                                         var counter=counter1 || 10
                                          // setup regex, no i  no g (only once, and case sensitive)
                                          var splitRegExp = /.*[S][(0-9)]+[E][(0-9)]+/;
                                          // loop thru the list of filenames
                                          for(filename of dataFile) {
                                              // if the name is not zero length (split could have returned for just linefeed
                                              if(filename.length >0 && counter >0) {
                                                 // get the filename prefix
                                                 var split = splitRegExp.exec(filename);
                                                 // save name to the output list, as a table entry
                                                 // remove space after the ->< , the forum hides everything after unless a space
                                                 // table has a row,
                                                 output_list.push("<tr><td>")
                                                 // with data
                                                 if(split)
                                                    output_list.push(split)
                                                 else
                                                     output_list.push('name not matched '+ filename)
                                                 // end of data and row
                                                 output_list.push("</td></tr>")
                                                 counter--;
                                          // insert the table into the wrapper
                              console.log( "<table>" + output_list.join('')+ "</table>");
                  This correct?
                    sgarg15 @sdetweil
                    @sdetweil Also how do i make it so that the python file is always running?
                      sdetweil @sgarg15
                      @sgarg15 that was the example of running a little js app on the command line node js_filename
                      The exact code here doesn’t help you, but the prior code I posted is what u want to try. Altho I don’t know how u will hook it to the sensors on your pc
                        @sgarg15 your python PGM has to loop somehow. I don’t do python
                          sgarg15
                          @sdetweil so, i have my python script running in the background, and in my nodeHelper.js i would have
                          let pyshell = new PythonShell('Swiping.py');  // < --- whatever your script name, in the module folder
                          could you explain what movement and message mean in the sendSocketNotification?
                          • E Offline
                            ertopps Banned
                            If you could help me achieve this, or give me some info that could help me do this i would really appreciate it
                              sdetweil @ertopps
                              @ertopps do what?
                              • E Offline
                                ertopps Banned
                                I am stuck due to similar issues. And now I need some professional developers with Python knowledge and good programming skills. I am from the US, check this out. And you need to be able during my working hours, it will be a great advantage for fruitful cooperation. Send me a message to my private box for more details. I do hope to find someone here with your assistance.
