    • Search
    MagicMirror² v2.20.0 is available! For more information about this release, check out this topic.
    SOLVED Wunderlist won't display entries
    Troubleshooting
    • binderth
      binderth last edited by
      Re: Wunderlist - Lists not showing up
      As described here, I configured everything like this:
      module: ‘MMM-Wunderlist’,
      position: ‘top_left’, // This can be any of the regions. Best results in left or right regions.
      header: ‘Einkaufsliste’, // This is optional
      accessToken: ‘xxxxxxxxxxxxxxxxxxxx’,
      clientID: ‘xxxxxx’,
      lists: [‘inbox’]
      // See ‘Configuration options’ for more information.
      For the test I did within the ./modules/MMM-Wunderlist:
      node fetcher_debug_client.js
      which showed:
      /home/pi/MagicMirror/modules/MMM-Wunderlist/fetcher_debug_client.js:59
      createFetcher(“id”, “Inbox”, 1000, accessToken, clientID);
      ReferenceError: accessToken is not defined
      is there something I missed? For the API-Key Generator in put in
      API URL: http://localhost:8080
      callback: https://a.wunderlist.com/api/v2/lists
      PS: Is there a possibility to have code formatted? 😉
      tidus5 1 Reply Last reply Reply Quote 0
      • tidus5
        tidus5 @binderth last edited by
        @binderth said in Wunderlist won't display entries:
        clientID: ‘xxxxxx’,
        lists: [‘inbox’]
        Yop,
        you forgot to add your access token, client ID and (maybe) the folder you want.
        you have the answer in the log - ReferenceError: accessToken is not defined
        dont change the API URL and the callback
        in your wondurlist account you can found the key and all
        binderth 1 Reply Last reply Reply Quote 0
        • binderth
          binderth @tidus5 last edited by
          @tidus5 said in Wunderlist won't display entries:
          sorry, I forgot to mention, in the post above, I crossed out my own accessToken and clientID. 😉 That’s what makes me wonder, because I defined my own keys in wundertlist API and put them in the config…?
          As I had difficulties to access my own Folder (which is within a group), I just wanted to access a system-folder provided by Wunderlist.
          • tidus5
            https://forum.magicmirror.builders/topic/213/wunderlist-your-todos-on-the-mirror/90
            maybe that can help you
            same error
            • binderth
              same error
              Perhaps I just don’t understand it… 😉
              But: at first, I did create my first keys with the PI’s browser, meaning I did not have any login in this browser yet. But i did created a new pair of keys, after I cleared the cache and stuff:
              https://developer.wunderlist.com/apps/new:
              • NAME: Magic Mirror
              • DESCRIPTION: beautiful mirror on the wall
              • APP URL: https://a.wunderlist.com/api/v1/lists
              • AUTH CALLBACK URL: http://localhost:8080
              after that, I get two Keys:
              • CLIENT ID: 20 characters
              • CLIENT SECRET: 60 characters
              Those key I fill in in my config:
              		module: 'MMM-Wunderlist',
              		position: 'top_left',  // This can be any of the regions. Best results in left or right regions.
              		header: 'Einkaufslisten', // This is optional
              			accessToken: 'CLIENT SECRET',
              			clientID: 'CLIENT ID',
              			lists: ['inbox'],
              			interval: '10',
              			fade: true
              but: I don’t get any information out of wunderlist. I don’t get an error in the console, but here’s the full console, if that helps:
              pi@MagicMirror:~/MagicMirror $ DISPLAY=:0 npm start
              magicmirror@2.0.0 start /home/pi/MagicMirror
              electron js/electron.js
              Loading config …
              Loading module helpers …
              Initializing new module helper …
              No helper found for module: MMM-Globe.
              No helper found for module: MMM-Callmonitor-Current-Call.
              No helper found for module: trainconnections.
              All module helpers loaded.
              Starting server op port 8080 …
              Server started …
              Connecting socket for: MMM-PIR-Sensor
              Staring module helper: MMM-PIR-Sensor
              Connecting socket for: MMM-Wunderlist
              Connecting socket for: MMM-FRITZ-Box-Callmonitor
              Starting module: MMM-FRITZ-Box-Callmonitor
              Connecting socket for: MMM-DWD-WarnWeather
              MMM-DWD-WarnWeather helper started…
              Starting module: newsfeed
              Sockets connected & modules started …
              Launching application.
              [2016-12-28 16:23:10] [MMM-PIR] Watching on GPIO #23 …
              Create new calendar fetcher for url: http://calendar.google.com/calendar/ical/xxx%40group.calendar.google.com/private-xxx/basic.ics - Interval: 300000
              Received config for MMM-FRITZ-Box-Callmonitor
              MMM-FRITZ-Box-Callmonitor is waiting for incoming calls.
              Starting access to FRITZ!Box…
              Create new news fetcher for url: http://rss.sueddeutsche.de/rss/Topthemen - Interval: 300000
              Create new calendar fetcher for url: http://calendar.google.com/calendar/ical/xxx/private-xxx/basic.ics - Interval: 300000
              Access to FRITZ!Box finished.
              [2016-12-28 16:23:34] [MMM-PIR] Motion detected
              [2016-12-28 16:23:34] [MMM-PIR] Not turning monitor ON, its already ON
              [2016-12-28 16:23:37] [MMM-PIR] Motion no longer detected
              [2016-12-28 16:23:37] [MMM-PIR] Turning Screen OFF in 120 seconds
              [2016-12-28 16:23:37] [MMM-PIR] Motion detected
              [2016-12-28 16:23:37] [MMM-PIR] Not turning monitor ON, its already ON
              Thanks for help!
              • binderth
                binderth @binderth last edited by
                Please be aware, that in the Wunderlist API there’s a CLIENT SECRET, which is exactly as long as the ACCESS TOKEN.
                The ACCESS TOKEN is not shown directly after generating the Keys, there’s a button “CREATE ACCESS TOKEN”, after that, the token is generated on the fly (note: it changes, everytime you press the button!). Then you can put in the token, which then resulted in my lists showing up in the MM as expected! 😉
                So please be aware, there are in fact three keys, only two are needed in config.js.
