    Wunderlist - Lists not showing up
    6 Posts 4 Posters 5.5k Views 4 Watching
    • N
      Notumlord
      I installed the Wunderlist module successfully, it shows up but no lists/tasks show up in the module.
      I’ve read this thread https://forum.magicmirror.builders/topic/213/wunderlist-your-todos-on-the-mirror/5 to try and solve this but so far no success.
      My wunderlist looks like this: http://imgur.com/oLYLYWi and http://imgur.com/a/yrbF7
      Finally my config.js looks like this:
          module: 'MMM-Wunderlist',
          position: 'top_left',  // This can be any of the regions. Best results in left or right regions.
          header: 'Wunderlist', // This is optional
                         accesToken: '<token generated by Create Acces Token',
                         clientID: '<client ID from my app view',
                         lists: [
                         			'today',
                         			'Mat'
                         interval: 10,
                         fade: true
      Any idea what the problem is?
      If relevant i haven’t installed the MM on an actual Pi yet, rather i followed yo-less instructions in this thread https://forum.magicmirror.builders/topic/548/building-mirror-without-programing/3 to test it out on a PC before i go out and buy a Pi and new monitor.
      • A
        amanzimdwini @Notumlord
        @Notumlord
        • can you have a look at the suggested solution in
          https://forum.magicmirror.builders/topic/388/wunderlist-acess-token
        that might help
        best,
        • N
          Notumlord
          I tried that already and it didn’t help unfortunately, as far as i’ve understood the URL’s doesn’t matter as long as an actual app isn’t published?
          Whats interesting is if i run the following cmd as suggested in the thread i linked in my OP "curl -H "X-Access-Token: H “X-Client-ID: https://a.wunderlist.com/api/v1/lists” It returns my lists (but not it’s content/tasks) so i don’t think it’s an token/authorization issue.
          • P
            paviro @Notumlord
            @Notumlord there should be a debug script in the module folder, can you try to run it (after you added your tokens at the button)? Run it with node name_of_debugger.js
            – The Doctor
            • M
              max72at
              @Notumlord I have exactly the same problem you are describing. "curl -H "X-Access-Token: H “X-Client-ID: https://a.wunderlist.com/api/v1/lists” shows my list but on Magic Mirror no list is shown at all. Did you find a solution meanwhile?
              • N
                Notumlord @max72at
                @max72at
                When i installed it on a Pi the module worked fine and showed all lists and their contents, maybe it’s an issue with node.js when installed on a regular PC?
