    Need help with MMM-BMWConnect
    10 Posts 3 Posters 2.1k Views 3 Watching
    • C Offline
      cenotaph
      I’m getting this error message upon starting MagicMirror:
      Failed to read file: Error: ENOENT: no such file or directory, open 'modules/MMM-BMWConnected/bmwtoken.json'
      Failed to read token:Couldn't find token in response
      I understand that the module is failing to create the token. Looking through the code, I see a reference to the “co.uk” site, as well as locale of “GB-en”. So I tried adding:
      apiBase: "www.bmw-connecteddrive.com"
      to config.js–still get the error. I wiped the module and pulled a fresh copy from github. I’ve validated my username/password by directly logging into the the US-based connecteddrive site.
      Anyone have a suggestion on how to fix this error?
        sdetweil @cenotaph
        @cenotaph said in Need help with MMM-BMWConnect:
        MMM-BMWConnected
        and u did these last two steps of install?
        cd MMM-BMWConnected
        npm install
        • C Offline
          cenotaph
          Yes.
          pi@raspberrypi:~/MagicMirror/modules/MMM-BMWConnected $ npm install
          added 3 packages from 7 contributors and audited 3 packages in 2.069s
          found 0 vulnerabilities
            sdetweil @cenotaph
            @cenotaph
            edit the module lib/tokenmanager.js
            add the line marked below
            console.log("token data ="+JSON.stringify(json))   // add this line before the one following already there
             if (typeof (json.token_type) === 'undefined' || typeof (json.access_token) === 'undefined') {
                _error("Couldn't find token in response");
                return;
            if using pm2, then stop mm, (pm2 stop 0)
            run your MM again with
            cd ~/MagicMirror
             npm start >somefile.txt
            then stop MM with ctrl-c
            then edit the somefile.txt
            and file the line
            “token data =”
            post the rest, its possible the api changed
            • C Offline
              cenotaph
              @sdetweil said in Need help with MMM-BMWConnect:
              console.log(“token data =”+JSON.stringify(json))
              [2020-05-09 16:47:59.840] [LOG]    token data ={"https://www.bmw-connecteddrive.com/app/default/static/external-dispatch.html?error":"access_denied"}
              I do have active subscriptions for Remote Services and BMW Connected+. I’m able to interact with cardata through the app on my phone (just in case there was a question as to whether or not I should be able to use the module.)
              I really appreciate your taking time to help me with this.
                sdetweil @cenotaph
                @cenotaph and u added your userid and password to the module config
                like this
                            email: "email@example.com",
                            password: "myComplexPassword"
                • C Offline
                  cenotaph
                  Yes. And I’ve copy/pasted from config.js to the login form on the web site to make sure that there’s no typo in config.js.
                    sdetweil @cenotaph
                    @cenotaph where r u located? in the US someplace
                      sdetweil @cenotaph
                      @cenotaph yeh, I think the authorization credentials in the token manager won’t work.
                      I don’t know where that came from … but I suspect it needs to be per user, like spotify, amazon, google, u need to make an ‘app’ with permissions to connect to the data
                      • P Offline
                        philmavedzenge
                        I have been using this module for the past 3 or so months. Initially I had the same issue. What you need to do is to download the powershell scripts from the module’s GitHub page. Run those and see if you get any data back. I can help you if you experience any issues with this.
                        You will have to try different end points until you find the correct one for your region. I then changed the locale as described in the above posts and it’s been working since.
                        I have since changed the module a bit to add more functionality.
