Need help with MMM-BMWConnect
10 Posts 3 Posters 1.3k Views 3 Watching
    cenotaph
    I’m getting this error message upon starting MagicMirror:
    Failed to read file: Error: ENOENT: no such file or directory, open 'modules/MMM-BMWConnected/bmwtoken.json'
    Failed to read token:Couldn't find token in response
    I understand that the module is failing to create the token. Looking through the code, I see a reference to the “co.uk” site, as well as locale of “GB-en”. So I tried adding:
    apiBase: "www.bmw-connecteddrive.com"
    to config.js–still get the error. I wiped the module and pulled a fresh copy from github. I’ve validated my username/password by directly logging into the the US-based connecteddrive site.
    Anyone have a suggestion on how to fix this error?
    S 1 Reply Last reply May 9, 2020, 4:49 PM Reply Quote 0
      sdetweil @cenotaph
      @cenotaph said in Need help with MMM-BMWConnect:
      MMM-BMWConnected
      and u did these last two steps of install?
      cd MMM-BMWConnected
      npm install
        cenotaph
        Yes.
        pi@raspberrypi:~/MagicMirror/modules/MMM-BMWConnected $ npm install
        added 3 packages from 7 contributors and audited 3 packages in 2.069s
        found 0 vulnerabilities
        S 1 Reply Last reply May 9, 2020, 7:51 PM Reply Quote 0
          sdetweil @cenotaph
          @cenotaph
          edit the module lib/tokenmanager.js
          add the line marked below
          console.log("token data ="+JSON.stringify(json))   // add this line before the one following already there
           if (typeof (json.token_type) === 'undefined' || typeof (json.access_token) === 'undefined') {
              _error("Couldn't find token in response");
              return;
          if using pm2, then stop mm, (pm2 stop 0)
          run your MM again with
           npm start >somefile.txt
          then stop MM with ctrl-c
          then edit the somefile.txt
          and file the line
          “token data =”
          post the rest, its possible the api changed
            cenotaph
            @sdetweil said in Need help with MMM-BMWConnect:
            console.log(“token data =”+JSON.stringify(json))
            [2020-05-09 16:47:59.840] [LOG]    token data ={"https://www.bmw-connecteddrive.com/app/default/static/external-dispatch.html?error":"access_denied"}
            I do have active subscriptions for Remote Services and BMW Connected+. I’m able to interact with cardata through the app on my phone (just in case there was a question as to whether or not I should be able to use the module.)
            I really appreciate your taking time to help me with this.
            S 1 Reply Last reply May 9, 2020, 9:59 PM Reply Quote 0
              sdetweil @cenotaph
              @cenotaph and u added your userid and password to the module config
              like this
                          email: "email@example.com",
                          password: "myComplexPassword"
                cenotaph
                Yes. And I’ve copy/pasted from config.js to the login form on the web site to make sure that there’s no typo in config.js.
                S 2 Replies Last reply May 10, 2020, 1:01 AM Reply Quote 0
                  sdetweil @cenotaph
                  @cenotaph where r u located? in the US someplace
                    sdetweil @cenotaph
                    @cenotaph yeh, I think the authorization credentials in the token manager won’t work.
                    I don’t know where that came from … but I suspect it needs to be per user, like spotify, amazon, google, u need to make an ‘app’ with permissions to connect to the data
                      philmavedzenge
                      I have been using this module for the past 3 or so months. Initially I had the same issue. What you need to do is to download the powershell scripts from the module’s GitHub page. Run those and see if you get any data back. I can help you if you experience any issues with this.
                      You will have to try different end points until you find the correct one for your region. I then changed the locale as described in the above posts and it’s been working since.
                      I have since changed the module a bit to add more functionality.
