    MMM-awesome-alexa "WARNING! electron-v6.1-linux-arm/snowboy.node"
    10 Posts 4 Posters 2.0k Views 4 Watching
      RATL
      Hello everyone!!
      I spend lots of hours trying to solve this problem and i think i will need your help.
      I Installed the Magic Mirror on my Raspberry Pi 4 and it´s working normal.
      The problem is when I insert the Alexa module (MMM-awesome-alexa), and I start the Magic Mirror I only see a “Black Screen” with the cursor.
      I try to see what kind of problem I receive on terminal it shows like this:
      Capturar
      According this I try to see the file “snowboy.node” on /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node , but I don´t have the folder “electron-v6.1-linux-arm”.
      I have …/Release/node-v64-linux-arm, and is nothing inside.
      I see some one that had the same problem and recommend to use this command on the MMM-awesome-alexa directory:
      npm run electron-rebuild
      But I receive another error:
      Capturar-2
      I appreciate the help of all of you.
      Thanks fsdfsd
      • ? Offline
        A Former User
        in the same directory try:
        ./node_modules/.bin/electron-rebuild
          RATL @Guest
          @Bugsounet said in MMM-awesome-alexa "WARNING! electron-v6.1-linux-arm/snowboy.node":
          Hello Bugsounet, tanks for your answer.
          I inserted that code on the MMM-awesome-alexa directory and I receive a message “No Such file or directory” image below.
          Capturar3
          I tried to install the module again using this steps: https://awesome-alexa.js.org/#/installation
          And i see that in this code :
          npm install --only=prod
          I receive some errors image below:
          Capturar4
          My problem is because of this errors installation?
          Really thanks for your help
          • ? Offline
            A Former User
            try installing electron-rebuild
            cd ~/MagicMirror/modules/MMM-awesome-alexa
            npm install electron-rebuild
            note:
            • i supose snowboy sources installed …
            • i don’t install this module ;)
              RATL
              Ok i used that code :
              Capturar6
              Afther that i try to open MagicMirror, the problem is the same “Black Screen” but now the error is different:
              Capturar7
              Really thanks for your help Bugsounet
              • ? Offline
                A Former User
                sorry, i can’t help you more, because i have not this module installed
                just maybe by trying npm install in alexa module directory (without --only-prod because it’s deprecied)
                if don’t work, i don’t know because it’s very old source and maybe unmaintened
                I see you open an issue in github, just wait a response
                  RATL
                  I tried to use that command on alexa module and i received some errors:
                  Ok i will wait for some more suggestions.
                  Thanks Bugsounet for your help and if you have other suggestion I appreciate it!
                  • W Offline
                    wirdman @RATL
                    @RATL @Bugsounet i got exacty the same probleme when i launching mmm-Google Assistant
                    • ? Offline
                      A Former User @wirdman
                      @wirdman really the same? :D
                        sdetweil
                        for awesome alexa, some of the 14 steps will cause errors, just keep going… I have a script that does them all
                        https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
                        can’t help on the GoogleAssistant side…
