    [npm library] @bugsounet/pir
    1 Posts 1 Posters 262 Views 1 Watching
      A Former User
      @bugsounet/pir
      I created this library if you want use a pir sensor in your module.
      This library is very simplified and ready for use in your node_helper.js
      This library is used in MMM-Assistant2Display
      single node routine for PIR sensor read
      Installation
      npm install @bugsounet/pir
      In the ending of installation, if you use electron you can do electron rebuild step.
      Do you want to execute electron rebuild ? [Y/n]
      Your choice:
      Sample with pir contructor
      const Pir = require("@bugsounet/pir")
      this.config = {
        gpio: 17,
        reverseValue: false
      var debug= false
      this.pir = new Pir(this.config, callback, debug)
      this.pir.start()
      setTimeout(() => { this.pir.stop() } , 5000)
      function callback(status, err) {
        console.log("[PIR:CALLBACK] Status: " + status)
        if (err) console.log("[PIR:CALLBACK] " + err)
      constructor of pir
      Pir(pirConfig, callback, debug)
      pirConfig {}
      • gpio - BCM-number of the sensor pin.
      • reverseValue - reverse presence detector value.
      callback (status,error)
      callback return with event status:
      • PIR_INITIALIZED: Pir constructor is initialized
      • PIR_STARTED: Pir start detection confirmation
      • PIR_STOP: pir stop detection confirmation
      • PIR_DETECTED: pir user presence detected
      • PIR_ERROR: pir error
      callback error return with PIR_ERROR
      if error detected, it will return it with error value
      debug
      if you want debuging information, just set to true
      Functions
      • start() : start pir
      • stop() : force stop pir
