    MMM-Screencast don`t work
    13 Posts 6 Posters 3.6k Views 6 Watching
      JohnBachini
      @Stevent Try changing port to something other than 8080, I’m guessing something else is using that port, Like MagicMirror itself.
        JohnBachini @JohnBachini
        @JohnBachini
        @sdetweil you beat me to it… :-)
          Stevent
          Sorry, here is the config, no custom Port in Screencast configurated.
          var config = {
          	address: "0.0.0.0", // Address to listen on, can be:
          	                      // Default, when address config is lefthttp://bulk.openweathermap.org/sample/city.list.json.gz out or empty, is "localhost"
          	port: 8080,
          	ipWhitelist: [], // Set [] to allow all IP addresses
          	language: "de",
          	timeFormat: 24,
          	units: "metric",
          			     // false, default for all  NON-armv6l devices
                      module: 'MMM-Remote-Control',  // uncomment the following line to show the URL of the remote control on the mirror
                      position: 'bottom_left',  // you can hide this module afterwards from the remote control itself
                          customCommand: {},  // Optional, See "Using Custom Commands" below
          		customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
          		showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                          pages: 2,
          			module: "MMM-Remote-Control-Repository",
                      module: 'MMM-AlexaControl',
                      position: 'middle_center',
                      image: false,
                      pm2ProcessName: "mm",
                      monitorToggle: true,
                      vcgencmd: "vcgencmd",
                      deviceName: "Spiegel",
          	        pages: 2
                  module: 'MMM-pages',
                          modules:
                              [[ "MMM-OpenmapWeather","weatherforecast","newsfeed","calendar", "compliments"],
                               [ "MMM-OpenmapWeather","MMM-Screencast"]],
                          fixed: ["clock", "currentweather", "MMM-AlexaControl", "MMM-page-indicator","MMM-Screencast"],
                  module: 'MMM-page-indicator',
                  position: 'bottom_bar',
                      pages: 2
          		module: 'MMM-Screencast',
          		position: 'bottom_right', // This position is for a hidden <div /> and not the screencast window
          			position: 'center',
          			// position: "center",
          			height: 300,
          			width: 500,
          			castName: "SpiegelRasp",
          JerryPJ 1 Reply Last reply Reply Quote 0
            JohnBachini
            @Stevent
            I quickly tried that module and it does work, what if you specify different port than 8080 in screencast config.
            If that makes no difference, what happens if you change ip address on which Magicmirror listens on at top of your config.
            address: “0.0.0.0”, //Address to listen on - Change this to ip of your MagicMirror.
              Stevent
              Not work change Port,
              but diferent pm2 log after change
              address: “0.0.0.0”,
              to
              address:“IPfromRASP”,
              0|MagicMir | [2020-06-15 20:28:02.945] [ERROR]  Error [ERR_SERVER_ALREADY_LISTEN]: Listen method has been called more than once without closing.
              0|MagicMir |     at Server.listen (net.js:1312:11)
              0|MagicMir |     at DialServer.start (/home/pi/MagicMirror/modules/MMM-Screencast/DialServer.js:122:17)
              0|MagicMir |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Screencast/node_helper.js:13:21)
              0|MagicMir |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:113:11)
              0|MagicMir |     at Socket.emit (events.js:200:13)
              0|MagicMir |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
              0|MagicMir |     at processTicksAndRejections (internal/process/task_queues.js:82:9)
                JohnBachini
                @Stevent i notice in your config for pages you have screencast twice , one in second page and one in fixed
                  Stevent
                  @JohnBachini said in MMM-Screencast don&#x60;t work:
                  I change it but no change in the log
                    AR2020 @Stevent
                    @stevent Im sure its your Alexa module, cut it off your config save the config file, try it after. If it works I have this same problem Alexa module conflicts with cast but its not the port i tried custom port on cast module.
                    • JerryPJ Offline
                      JerryP @Stevent
                      @stevent said in MMM-Screencast don&#x60;t work:
                       		position: 'center',
                       		height: 300,
                       		width: 500,
                      		castName: 'SpiegelRasp',
                      Pleas tray this to copy past in your config file
                      i’ts working one mine
