    MMM-DarkSkyForecast Loading...
    mmm-darkskyforecastloadingnot working
    19 Posts 4 Posters 5.9k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer @P_Tmans
      @P_Tmans have you been actively using it? Can you still log in at https://darksky.net/dev/login ?
      • P Offline
        P_Tmans @chassain 0
        @chassain-0 i don’t know what i should be looking for in my config, that’s kind of my main issue
        • P Offline
          P_Tmans @BKeyport
          @BKeyport yea i can still log in, it’s still active it just shows no usage, as the module isn’t working at the moment
          • C Offline
            chassain 0 @P_Tmans
            @P_Tmans edit your config here and i will check with my api key
            • P Offline
              P_Tmans @chassain 0
              @chassain-0 defaults: {
              apikey: “”,
              latitude: “52.448896”,
              longitude: “-1.74335”,
              updateInterval: 10, // minutes
              requestDelay: 250,
              units: “uk2”,
              showCurrentConditions: true,
              showExtraCurrentConditions: true,
              showSummary: true,
              forecastHeaderText: “”,
              showForecastTableColumnHeaderIcons: true,
              showHourlyForecast: true,
              hourlyForecastInterval: 3,
              maxHourliesToShow: 3,
              showDailyForecast: true,
              maxDailiesToShow: 3,
              showPrecipitation: true,
              concise: true,
              showWind: true,
              language: config.language,
              iconset: “2c”,
              useAnimatedIcons: true,
              animateMainIconOnly: true,
              colored: true,
              forecastLayout: “tiled”,
              showInlineIcons: true,
              mainIconSize: 100,
              forecastTiledIconSize: 70,
              forecastTableIconSize: 30,
              updateFadeSpeed: 500,
              label_maximum: “max”,
              label_high: “H”,
              label_low: “L”,
              label_timeFormat: “h a”,
              label_days: [“Sun”, “Mon”, “Tue”, “Wed”, “Thur”, “Fri”, “Sat”],
              label_ordinals: [“N”, “NNE”, “NE”, “ENE”, “E”, “ESE”, “SE”, “SSE”, “S”, “SSW”, “SW”, “WSW”, “W”, “WNW”, “NW”, “NNW”],
              moduleTimestampIdPrefix: “DARK_SKY_TIMESTAMP_”
              that’s the config i have for the MMM-DarkSky Forecast.js ^
              	 	 module: "MMM-DarkSkyForecast",
              	 	 header: "Weather",
              	 	 classes: "default everyone",
              	 	 disabled: false,
              	 	   apikey: "",
              	 	   latitude: "52.448896",
              	 	   longitude: "-1.74335",
              	 	   iconset: "2c",
              	 	   concise: false,
              	 	   forecastLayout: "tiled"
              thats the config i have for the config.js file ^
              C S 2 Replies Last reply Reply Quote 0
              • C Offline
                chassain 0 @P_Tmans
                @P_Tmans said in MMM-DarkSkyForecast Loading...:
                     iconset: "2c",
                     concise: false,
                Only with the config.js it’s ok for me
                • P Offline
                  P_Tmans @chassain 0
                  @chassain-0 alright, thanks for checking, i guess i should reinstall the module and go from there?
                  • C Offline
                    chassain 0 @P_Tmans
                    @P_Tmans i think…and add only parameters to the config.js and not darsky…js
                    • P Offline
                      P_Tmans @chassain 0
                      @chassain-0 oh ok, i’ll give that a go then, thanks for the help
                      C 1 Reply Last reply Reply Quote 1
                      • C Offline
                        chassain 0 @P_Tmans
                        @P_Tmans one by one to begin
