    Trouble with modules
    4 Posts 2 Posters 693 Views 2 Watching
    • N Offline
      nipper2000h
      Hello,
      I am new to programming and having trouble installing new modules. I have only been able to get the doomsday countdown timer to work successfully. I am currently having trouble with NJ Transit Bus module. I have installed the module, changed directory to the module folder and installed the dependencies by following the readme file. The module seems to load into MM but never actually loads any data or seems to connect to any service. This module does not require an API. I have failed to get the MMM-NycTransit module or MMM-Traffic module to work correctly so I figured my problem was API related? I get the same result from both these modules as well, the module seems to work but doesn’t get any information. I figured this module without an API was a good place to start troubleshooting.
      I’ve checked for syntax errors. Here is my NJTransitBus config:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: "MMM-NJTransit",
      			position: "lower_third",
      			header: "NJ Transit buses",
      				colored: true,
      				stops: [{
      					label: "North st",
      					color: "yellow",
      					routes: ["40"]
      					label: "George rd",
      					color: "green"
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      			module: "compliments",
      			module: "currentweather",
      				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "myweatherAPI"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      This is a SS of the mirror.
      Here’s what I get when I start MM:
      > magicmirror@2.11.0 start /home/pi/MagicMirror
      [2020-06-14 20:31:25.419] [LOG]    Starting MagicMirror: v2.11.0
      [2020-06-14 20:31:25.652] [LOG]    Loading config ...
      [2020-06-14 20:31:25.666] [LOG]    Loading module helpers ...
      [2020-06-14 20:31:27.145] [LOG]    Initializing new module helper ...
      [2020-06-14 20:31:27.148] [LOG]    Module helper loaded: MMM-NJTransit
      [2020-06-14 20:31:27.150] [LOG]    No helper found for module: alert.
      [2020-06-14 20:31:27.265] [LOG]    Initializing new module helper ...
      [2020-06-14 20:31:27.267] [LOG]    Module helper loaded: updatenotification
      [2020-06-14 20:31:27.270] [LOG]    No helper found for module: clock.
      [2020-06-14 20:31:29.311] [LOG]    Initializing new module helper ...
      [2020-06-14 20:31:29.316] [LOG]    Module helper loaded: calendar
      [2020-06-14 20:31:29.320] [LOG]    No helper found for module: compliments.
      [2020-06-14 20:31:29.322] [LOG]    No helper found for module: currentweather.
      [2020-06-14 20:31:29.325] [LOG]    No helper found for module: weatherforecast.
      [2020-06-14 20:31:29.485] [LOG]    Initializing new module helper ...
      [2020-06-14 20:31:29.488] [LOG]    Module helper loaded: newsfeed
      [2020-06-14 20:31:29.490] [LOG]    All module helpers loaded.
      [2020-06-14 20:31:30.145] [LOG]    Starting server on port 8080 ...
      [2020-06-14 20:31:30.185] [LOG]    Server started ...
      [2020-06-14 20:31:30.187] [LOG]    Connecting socket for: MMM-NJTransit
      [2020-06-14 20:31:30.189] [LOG]    Starting node helper for: MMM-NJTransit
      [2020-06-14 20:31:30.190] [LOG]    Connecting socket for: updatenotification
      [2020-06-14 20:31:30.191] [LOG]    Connecting socket for: calendar
      [2020-06-14 20:31:30.193] [LOG]    Starting node helper for: calendar
      [2020-06-14 20:31:30.195] [LOG]    Connecting socket for: newsfeed
      [2020-06-14 20:31:30.198] [LOG]    Starting module: newsfeed
      [2020-06-14 20:31:30.202] [LOG]    Sockets connected & modules started ...
      [2020-06-14 20:31:30.618] [LOG]    Whoops! There was an uncaught exception...
      [2020-06-14 20:31:30.619] [ERROR]  Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
          at Server.setupListenHandle [as _listen2] (net.js:1226:14)
          at listenInCluster (net.js:1274:12)
          at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '127.0.0.1',
        port: 8080
      [2020-06-14 20:31:30.648] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-06-14 20:31:30.649] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2020-06-14 20:31:30.656] [LOG]    Launching application.
      Any help would be greatly appreciated! Thank you.
        sdetweil @nipper2000h
        @nipper2000h the second means u already have mm running. did u select pm2 during the scripted install?
        do
        pm2 status
        pm2 stop 0
        then restart mm again
        • N Offline
          nipper2000h @sdetweil
          @sdetweil Yes, this worked. Thank you so much, it fixed my issue on all the modules I was having problems with. I didn’t realize anything was wrong because weather was working twice. MM was running from pm2 already when I used npm start. Restarts didn’t fix my issue but this worked for me. Thanks again!
            @nipper2000h awesome! glad u found it.
            thank you for good diagnostic info!!
