    Mirror not displaying any modules
    16 Posts 7 Posters 5.2k Views 6 Watching
    • Eric_HE Offline
      Eric_H @BKeyport
      @BKeyport Thank you
        sdetweil @SamBro2901
        @SamBro2901 did u install w my script? or manually?
        the already in use means something else on your system is using the networking setup mm needs.
        maybe u have another instance running…
        do
        pm2 status
          @SamBro2901 do this
          sudo netstat -a | grep 8080
          • I Offline
            itx
            same here. Rebooted RasPi many times, changed port in config file to 9080 but mirror is not displaying anything.
            Output is still the same:
            pi@magicmirror:~/MagicMirror $ npm run config:check
            > magicmirror@2.12.0 config:check /home/pi/MagicMirror
            > node js/check_config.js
            [2020-08-07 09:53:37.955] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
            [2020-08-07 09:53:38.247] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
            /home/pi/MagicMirror/js/check_config.js:66
            			throw new Error("Wrong syntax in config file!");
            Error: Wrong syntax in config file!
                at /home/pi/MagicMirror/js/check_config.js:66:10
                at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the magicmirror@2.12.0 config:check script.
            npm ERR!     /home/pi/.npm/_logs/2020-08-07T07_53_38_325Z-debug.log
            What else can I try?
              sdetweil @itx
              @itx config:check is broken
              what is the original error from npm start?
                sdetweil @itx
                @itx see the pinned topic at the top on this subject area for the temp fix to config:check
