    Mirror not displaying any modules
    16 Posts 7 Posters 6.8k Views 6 Watching
      sdetweil @SamBro2901
      @SamBro2901 you did manual install?
      git clone and then npm install?
      is this on raspian, Linux, ?
        @SamBro2901 looks like there were two instances running. are you using pm2 to start one instance?
        pm2 status will show you
        • MichMichM
          MichMich
          There is already something running on port 8080. A simple solution often is to just restart your Pi. :)
            SamBro2901 @sdetweil
            @sdetweil I did a manual install doing git clone and then npm install on raspbian and no, I haven’t used pm2 to run my instance, is that what I am doing wrong?
            Also, what about the error I get when running the config check?
              SamBro2901 @MichMich
              @MichMich I changed the port in the config.js and it works perfectly fine now, thanks for the help and for this wonderful project :)
              ? 1 Reply Last reply
                A Former User @SamBro2901
                @SamBro2901 I’m getting this same error. What did you change the port to?
                  sdetweil @Guest
                  @ktvoort123 pick a port, add one or 10, or 100.
                  • Eric_HE
                    Eric_H
                    Same here.
                    @MichMich this started after I updated my Raspbian to the latest, and now getting this error that I cannot resolve:
                    > node js/check_config.js
                    [2020-07-23 17:51:02.700] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                    [2020-07-23 17:51:03.283] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
                    /home/pi/MagicMirror/js/check_config.js:66
                                            throw new Error("Wrong syntax in config file!");
                    Error: Wrong syntax in config file!
                        at /home/pi/MagicMirror/js/check_config.js:66:10
                        at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                    I’d appreciate an advise.
                    Thank you.
                    BKeyportB 1 Reply Last reply
                    • BKeyportB
                      BKeyport Module Developer @Eric_H
                      @Eric_H config:check hasn’t worked as of 2.12.
                      Gonna have to manually run through for now.
                      Eric_HE 1 Reply Last reply
                      • Eric_HE
                        Eric_H @BKeyport
                        @BKeyport Thank you
                          @SamBro2901 did u install w my script? or manually?
                          the already in use means something else on your system is using the networking setup mm needs.
                          maybe u have another instance running…
                          do
                          pm2 status
                            @SamBro2901 do this
                            sudo netstat -a | grep 8080
                            • I
                              itx
                              same here. Rebooted RasPi many times, changed port in config file to 9080 but mirror is not displaying anything.
                              Output is still the same:
                              pi@magicmirror:~/MagicMirror $ npm run config:check
                              > magicmirror@2.12.0 config:check /home/pi/MagicMirror
                              [2020-08-07 09:53:37.955] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                              [2020-08-07 09:53:38.247] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno 1
                              npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                              npm ERR!     /home/pi/.npm/_logs/2020-08-07T07_53_38_325Z-debug.log
                              What else can I try?
                              S 2 Replies Last reply
                                sdetweil @itx
                                @itx config:check is broken
                                what is the original error from npm start?
                                  sdetweil @itx
                                  @itx see the pinned topic at the top on this subject area for the temp fix to config:check
