    Mirror not displaying any modules
    16 Posts 7 Posters 5.2k Views 6 Watching
      SamBro2901
      I recently installed the magic mirror repo following the instructions from the docs. I did everything and it all worked fine, until the time came to run it. I did npm run start and it showed this,
      > magicmirror@2.12.0 start /home/pi/MagicMirror
      [2020-07-05 11:02:41.744] [LOG]    Starting MagicMirror: v2.12.0
      [2020-07-05 11:02:41.812] [LOG]    Loading config ...
      [2020-07-05 11:02:41.859] [LOG]    Loading module helpers ...
      [2020-07-05 11:02:41.871] [LOG]    No helper found for module: alert.
      [2020-07-05 11:02:42.124] [LOG]    Initializing new module helper ...
      [2020-07-05 11:02:42.127] [LOG]    Module helper loaded: updatenotification
      [2020-07-05 11:02:42.131] [LOG]    No helper found for module: clock.
      [2020-07-05 11:02:44.063] [LOG]    Initializing new module helper ...
      [2020-07-05 11:02:44.065] [LOG]    Module helper loaded: calendar
      [2020-07-05 11:02:44.069] [LOG]    No helper found for module: compliments.
      [2020-07-05 11:02:44.072] [LOG]    No helper found for module: currentweather.
      [2020-07-05 11:02:44.075] [LOG]    No helper found for module: weatherforecast.
      [2020-07-05 11:02:44.203] [LOG]    Initializing new module helper ...
      [2020-07-05 11:02:44.205] [LOG]    Module helper loaded: newsfeed
      [2020-07-05 11:02:44.207] [LOG]    All module helpers loaded.
      [2020-07-05 11:02:44.772] [LOG]    Starting server on port 8080 ...
      [2020-07-05 11:02:44.848] [LOG]    Server started ...
      [2020-07-05 11:02:44.852] [LOG]    Connecting socket for: updatenotification
      [2020-07-05 11:02:44.856] [LOG]    Connecting socket for: calendar
      [2020-07-05 11:02:44.858] [LOG]    Starting node helper for: calendar
      [2020-07-05 11:02:44.860] [LOG]    Connecting socket for: newsfeed
      [2020-07-05 11:02:44.862] [LOG]    Starting node helper for: newsfeed
      [2020-07-05 11:02:44.865] [LOG]    Sockets connected & modules started ...
      Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
      [2020-07-05 11:02:45.782] [ERROR]  Whoops! There was an uncaught exception...
      [2020-07-05 11:02:45.785] [ERROR]  Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
          at Server.setupListenHandle [as _listen2] (net.js:1226:14)
          at listenInCluster (net.js:1274:12)
          at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '127.0.0.1',
        port: 8080
      [2020-07-05 11:02:45.815] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-07-05 11:02:45.830] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2020-07-05 11:02:45.890] [LOG]    Launching application.
      [2020-07-05 11:03:24.978] [LOG]    Shutting down server...
      [2020-07-05 11:03:24.990] [LOG]    Stopping module helper: updatenotification
      [2020-07-05 11:03:24.993] [LOG]    Stopping module helper: calendar
      [2020-07-05 11:03:24.995] [LOG]    Stopping module helper: newsfeed
      I then decided to run the config check and see if I did something wrong and was hit with this error:
      > magicmirror@2.12.0 config:check /home/pi/MagicMirror
      > node js/check_config.js
      [2020-07-05 11:10:58.675] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
      [2020-07-05 11:10:59.193] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
      /home/pi/MagicMirror/js/check_config.js:66
      			throw new Error("Wrong syntax in config file!");
      Here’s my config.js:
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      var config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "1277333", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "4b32b21aaee5dd9ae4585256eed97703"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      I’m a complete newbie in this department and would appreciate any help you guys can offer :)
        sdetweil @SamBro2901
        @SamBro2901 you did manual install?
        git clone and then npm install?
        is this on raspian, Linux, ?
          @SamBro2901 looks like there were two instances running. are you using pm2 to start one instance?
          pm2 status will show you
          • MichMichM Offline
            MichMich
            There is already something running on port 8080. A simple solution often is to just restart your Pi. :)
              SamBro2901 @sdetweil
              @sdetweil I did a manual install doing git clone and then npm install on raspbian and no, I haven’t used pm2 to run my instance, is that what I am doing wrong?
              Also, what about the error I get when running the config check?
                SamBro2901 @MichMich
                @MichMich I changed the port in the config.js and it works perfectly fine now, thanks for the help and for this wonderful project :)
                  A Former User @SamBro2901
                  @SamBro2901 I’m getting this same error. What did you change the port to?
                    sdetweil @Guest
                    @ktvoort123 pick a port, add one or 10, or 100.
                    • Eric_HE Offline
                      Eric_H
                      Same here.
                      @MichMich this started after I updated my Raspbian to the latest, and now getting this error that I cannot resolve:
                      [2020-07-23 17:51:02.700] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
                      [2020-07-23 17:51:03.283] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
                      Error: Wrong syntax in config file!
                          at /home/pi/MagicMirror/js/check_config.js:66:10
                          at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                      I’d appreciate an advise.
                      Thank you.
                      • BKeyportB Offline
                        BKeyport Module Developer @Eric_H
                        @Eric_H config:check hasn’t worked as of 2.12.
                        Gonna have to manually run through for now.
                        Eric_HE 1 Reply Last reply Reply Quote 1
