    Cannot exit MM after recent update
    4 Posts 3 Posters 705 Views 3 Watching
    • T Offline
      tasanford11
      I just updated my Magic Mirror setup (following the
      git pull && npm install
      I had everything almost all set to get started with the Mirror, and now everything is all sorts of jacked up. I had my modules configured, APIs set up, and the Pi was configured.
      The Issue:
      • After the updating my local repo, I rebooted.
        • On reboot, pm2 took over and started MM.
        • Previously, I could ‘Ctrl + Q’, open the terminal, and ‘pm2 stop MM’
          • Now when I ‘Ctrl + Q’ MM will almost instantly reboot, not allowing me to get a terminal open to stop pm2.
      I have tried the Windows key to access Terminal that way and it does not work (it worked previously before updating). I have also tried minimizing the window: all this does is leave me with a black screen where I still cannot get to a terminal to stop pm2. Full shutdowns, reboots, nothing is working. MM has now taken over my Pi since the update. This was never an issue prior. All so I could simply get rid of the update notification at the top of the screen.
      *P.S. After the update, the forecasted weather has now shrunk down to 1 day. This is much less of a priority, I’m happy to troubleshoot this on my own once I can close the dang mirror and get back to a terminal/files.
      Thank you in advance!
        sdetweil @tasanford11
        @tasanford11 alt-spacebar, n
        should minimize the mm window.
        if u have another full screen black window, do alt-spacebar, n again. the desktop is back there.
        ctrl-q was never a good approach, as pm2’s job is to restart the app immediately if it goes gown unexpectedly.
        • T Offline
          tasanford11 @sdetweil
          Thank you for the help! This allowed me to get a Terminal emulator opened up and work backwards. I appreciate it!
          • mumblebajM Offline
            mumblebaj Module Developer @tasanford11
            @tasanford11 ctrl+alt+t usually works for me. This pops open a terminal window immediately.
