    Config problems
    8 Posts 2 Posters 1.3k Views 2 Watching
      dawookie1979
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "clock",
      			position: "top_left"
      			header: "xxxxx Family Calendar",
      			position: "bottom_left",
      						symbol: "xxxxx Family",
      						url: "https://calendar.google.com/calendar/ical/xxxxx.com/public/basic.ics"
      		{				symbol: "uk holiday",
      				url: "https://calendar.google.com/calendar/ical/en-gb.uk%23holiday%40group.v.calendar.google.com/public/basic.ics"
      			module: "currentweather",
      				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
      				appid: "xxxxx"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "xxxxx"
      	module: 'MMM-SoccerLiveScore',
      	position: 'left',
      	header: 'Live Football Scores',
      		leagues: [17],
              showNames: true,
              showLogos: true,
              displayTime: 60 * 1000,
              showTables: false
        module: "MMM-CountEvents",
        position: "left",
          groupOrder: [], // When it set, the group of event which has same group name will be displayed and be rotated to others by groupInterval
          groupInterval: 1000*5,
          refreshInterval:1000*1,
          locale: null, //related with `humanize` (if omitted or null, MM default locale will be used.)
          template: "<p class=\"title\">%TITLE%</p><p class=\"output\">%OUTPUT%</p>",
          //You can modify HTML rendering.
          //%TITLE% : will be replaced by event.title
          //%OUTPUT% : will be replaced by event.output
          events: [
              group: "default",
              title: "Daniel's Alcohol Free",
              targetTime: "2019-09-24", // See the time format section.
            	yearlyRepeat: false, // if this event should be refreshed yearly, set this to `true`. targetTime will be replaced the closest next date of this year or the next year.
            	unit: "days", // "years", "months", "weeks", "days", "hours", "minutes", "seconds"...
              //but if you set `humanize` to true, `unit` will be ignored.
            	humanize:false, //If set as `true`, %RESULT% will be humanized. (e.g "a year ago")
              absolute:true, //If set as `false`, remain duration will be `plus number`, past duration will be `minus number`. If set as `true`, all duration will be `plus number`
              ignore:null, //Available [null, "before", "after"]. This event will not be displayed `before|after` targetTime
              className: "", //You can assign class name to this event for beautifying with CSS.
            	output: "%RESULT% days passed", //You can modify output text. %RESULT% will be result of countdown/up calculation with above options.
              group: "default",
              title: "Emma's Alcohol Free",
              targetTime: "2019-09-26", // See the time format section.
      		module: 		'MMM-UKNationalRail',
      		position: 		'bottom_left',
      		header:			'Whittlesford Parkway',		//Optional - delete this line to turn OFF the header completely
      			stationCode: 		'WLF', 		// CRS code for station
      			app_id: 			'xxxxx', 		// TransportAPI App ID
      			app_key: 			'xxxxx', 		// TransportAPI App Key
      			maxResults: 		5,  		//Optional - Maximum results to display.
      			showOrigin: 		false   	//Optional - Show the origin of the train in the table
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "BBC News",
      						url: "http://feeds.bbci.co.uk/news/rss.xml?edition=uk"
      				showSourceTitle: true,
      				showPublishDate: true
        dawookie1979
        can anyone see problems?
          sdetweil @dawookie1979
          @dawookie1979
          u have this in the middle of the modules list
            dawookie1979
            yes i have removed that, but still no joy
              @dawookie1979 my post did not show All that was trouble
                dawookie1979
                lol, ok. i have added/taken away {}. it now seems to work :0 . Thank you for your help
                  dawookie1979
                  how do i mark this as solved :)
                    @dawookie1979 u didn’t open it as an issue that is closable, so only can edit the title to add solved
