    I've finally gotten the mirror, now how do I mount it?
    3 Posts 2 Posters 717 Views 2 Watching
    • F Offline
      fribse
      So the mirror has finally arrived, I’ve built the frame some time ago, and not the mirror is here, I’m trying to figure out the right way to mount it.
      I wanted it to be ‘frameless’, but how do I ‘black out’ the area outside the monitor, paint it with something? And if I do that, how do I fasten it to the frame, so the glue isn’t visible through the mirror? Or should I abandon the complately frameless idea, and mount small holders for the mirror?
      I’m also considering changing the monitor, it’s currently a monitor from a stationary computer, and I’ve gotten a panel from a laptop lying around now, but I guess I have to find out how much light the two generate to choose the right one.
        sdetweil @fribse
        @fribse well, u have to coat the unused portion w something. so paint is a way.
        mount mirror to frame of frameless??
        typically those have holes drilled thru the glass so you can attach it to the backing frame
        • F Offline
          fribse @sdetweil
          @sdetweil Ok, well I was thinking at first I would glue it, but I’ll get those small mirror brackets that just holds the edges.
          Is there a good kind of paint for the backside of it?
