    Extension of MMM-Tools (Bugsounet)
    30 Posts 6 Posters 8.9k Views 6 Watching
      MiPraSo
      I would like to extend the module.
      I would like to display both IP addresses.
      What I have already done:
      Changed the cmdline.txt to show a wlan0 as interface name again (ifconfig)
      In node-helper.js I added the following:
      IP: "ip -4 a show lo | grep inet",
      IP_LAN: "ip -4 a show eth0 | grep inet"
      IP_WLAN: "ip -4 a show wlan0 | grep inet"
      Implemented these two functions:
       getIP_WLAN : function() {
          exec (this.scripts['IP_WLAN'], (err, stdout, stderr)=>{
            if (err == zero) {
              this.WLAN = stdout.trim().match(/\b\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}\b/)
        getIP_LAN : function() {
          exec (this.scripts['IP_LAN'], (err, stdout, stderr)=>{
            if (err == zero) {
              var matched = stdout.trim().match(/\b\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}\b/)
              this.IP_LAN = (matched) ? matched[0] : "Unknown"
      Unfortunately, I did not get any further, I can’t manage to output the values. My goal is what is written there:
      IP       eth0: 192.168.1.xx, wlan0: 192.168.1.yy
      Since I have no experience with JS, I am now stucking here…
      Is anyone interested in helping me with this?
      Greetings
        sdetweil @MiPraSo
        @MiPraSo in mm, the node_helper is the data ( ip addresses) collector,
        and the modulename.js is the data presenter. See the getDom() routine which builds the html content to be displayed
        • ? Offline
          A Former User
          Hi, thanks for you feedback ;)
          don’t worry about this !
          I will start the MMM-Tools v2 in a few days !
          I will start this module with new code and a new tool without sh script :)
          of course it will have news functionally like yours
            MiPraSo
            Hi @Bugsounet,
            I’ll be patient and I’ll wait…
            Let me be your alpha and beta tester. :lady_beetle:
            Thanks for your feedback.
            • ? Offline
              A Former User
              In the last update I add uptime and uptime Record
              now, I be back for some news !
              I changed the code by the new library without sh / bash script and here is the performance:
              [2020-08-11 01:32:07.710] [LOG]    CPU Usage 9
              [2020-08-11 01:32:07.724] [LOG]    CPU Temp: 44
              [2020-08-11 01:32:07.726] [LOG]    Mem Total 7934
              [2020-08-11 01:32:07.726] [LOG]    Mem used 3212
              [2020-08-11 01:32:07.726] [LOG]    Mem % 40
              so very good react ;)
              now i will try:
              • display info about / partition and /home partition (choice of user of course)
              • display ALL used ip adress (and trafic if you want)
              • maybe determinate % of cpu used with MagicMirror (maybe because not tested)
              • what 'is the users connected
              • display RPI version
              Sure, all info will not displayed in config by default. You can enable (or disable) it as you want ;)
              After, the question is :
              I keep the current visual or I change !?
              • ? Offline
                A Former User
                Hi !
                MMM-Tools fetch all info needed : (tested on my dev platform and not definitive)
                [2020-08-13 17:55:13.191] [LOG]    Send this Status: {
                  OS: 'Debian 10 (buster)',
                  SYS: 'Core™ i5-3350P',
                  NETWORK: [
                    enp3s0: { ip: '192.168.0.17', type: 'wired', default: true },
                    wlx98ded00d0521: { ip: '192.168.0.193', type: 'wireless', default: false }
                  MEMORY: [ total: '7934Mb', used: '2613Mb', percent: '40' ],
                  STORAGE: [
                    '/': { size: '39.98Go', used: '10.33Go', use: 25.84 },
                    '/home': { size: '383.49Go', used: '53.64Go', use: 13.99 },
                    '/boot/efi': { size: '96.00Mo', used: '31.57Mo', use: 32.89 },
                    '/media/Data': { size: '540.76Go', used: '96.68Go', use: 17.88 }
                  CPU: [ temp: '44.0', usage: '23' ],
                  UPTIME: '1 jour 17 heures 25 minutes',
                  RECORD: '27 jours 18 heures 49 minutes',
                  SCREEN_STATUS: 'OFF'
                of course SYS info is the result of CPU type or RPI type
                exemple for a RPI 4:
                SYS: 'Raspberry Pi 4 Model B Rev 1.1'
                RPI 3:
                SYS: 'Raspberry Pi 3 Model B Plus Rev 1.3'
                Now, i will do a new visual for displaying all information received ;)
                Note: If somebody need other information to display, just tell me :)
                • ? Offline
                  A Former User
                  This is current information and visual fetched in my dev branch
                  Raspberry:
                  My dev platform:
                  Of course, you can hide, if you want, not needed partitions info.
                  if you have multiple network, the default network is represented with a star
                  • You can try the dev branch with this command:
                  (assumed that v1 is installed)
                  cd ~/MagicMirror/modules/MMM-Tools
                  git checkout -f dev
                  npm install
                  • to return to v1:
                  git checkout -f master
                  npm install
                  do not hesitate to give me feedback.
                  if any other informations is missing, just tell me :)
                    MiPraSo @Guest
                    @Bugsounet
                    Looks good…
                    Here’s some issues:
                    1. Is there an example for the config.cfg?
                    2. The alignment is now right again, in the old version I was able to adjust it to the left?
                    3. How do I get the display wider, in the old version I could adjust it?
                    4. How can I change the label, from UPTIME to Laufzeit or *LAN to eth0?
                    5. And what are “Go” and “Mo” which should be about “GB” and “MB”?
                    Regards,
                    Michael
                    • ? Offline
                      A Former User
                      1. I force all value to display, I don’t really add some feature to personalize actually
                        you can’t actually config:
                        recordUptime: true, to record and display : record uptime
                        partitionExclude : [], fo exclude partition to display
                        sample: partitionExclude : [ "/boot" ], if you don’t want display info about /boot partition
                      2. I have to ajust css code
                      3. not coded yet (personal feature will be coded in the end)
                      4. I’m trying to do a translation file (wait a while ;) )
                        just tell me what value to translate (and translation needed)
                        For Lan to eth0. I have fetch the name info by not displayed actually (because in my dev the WLAN interface have a very very long name)
                        so i have planned a feature for name choice displaying (native or WLAN/LAN)
                      5. I will do dual code (actually it’s a test)
                      I will be back to you when i have done some totentials change
                      • ? Offline
                        A Former User
                        Yeah !
                        • I have just commit some change on dev branch
                        • I add the new configuration part in Readme
                        • I correct some css code
                        • I correct unit Go to Gb
                        • added translation file (de too)
                          actually supported : en, fr, de (thx to @lxne), id (80% done) and sv (thx to @el97 from github), it (thx to @MrDondoT from github)
                          I can add other language just help me to do the translate file
                        • added telegramBot command /status
                        MagicMirror:
                        TelegamBot:
                        • ? Offline
                          A Former User
                          new change:
                          useMagicMirror: true, in UPTIME: {}
                          for choice of system uptime (since boot) or magic mirror uptime
                            robertybob
                            I’m liking these developments, I’m watching with great interest :)
                            • ? Offline
                              A Former User
                              I finalize ;) and go to master !
                              You can try it, if you want
                              git clone -b dev https://github.com/bugsounet/MMM-Tools
                              cd MMM-Tools
                              npm install
                              and read the dev readme for config
                              Edit for ALL!
                              • Dev is now freeze and waiting for YOUR debug, corrects or additions
                              • For me it’s ready for release :)
                              • Give me your Feedback !
                              • I can display all user connected but … really interesting, i don’t know ??
                              • Maybe i have forget something ?
                              I do this module for you !
                              actually for my usage, it’s ok
                              so tell me what do you want to display ;)
                              • ? Offline
                                A Former User
                                So ?
                                Added : MMM-TelegramBot warning (wanted by @lxne)
                                Modified translation: it (thx @Cr4z33) , de (thx @lxne)
                                Can I Release it ? nothing else to add ?
                                • ? Offline
                                  A Former User
                                  MMM-Tools v2.0.0 is now Released !
                                  Please Read wiki for new configuration
                                    robertybob @Guest
                                    @Bugsounet I will download it this week and report back ! :D
                                    • ? Offline
                                      A Former User
                                      no problem, in all case, I release it (It is necessary, otherwise I will never do it!)
                                      It’s not because I’m releasing that I’m going to drop the project!
                                      if necessary I will add new request or correct some bug (maybe if happen)
                                      when i promise something i try to do my best for you all ! :)
                                        MrDondoT
                                        @Bugsounet - fyi using the module with MMM-TelegramBot happens that “The usage of CPU is …” over 100% (129 percent), I even got 238 percent
                                        • ? Offline
                                          A Former User
                                          yes i know, i try an average value of cpu usage, i don’t know about the unit return value … I have X100 value but i think it’s not that
                                          so disable it (set it to 0), i will see
                                          • ? Offline
                                            A Former User
                                            so … what is he unit of this:
                                            load average: 0,97, 0,72, 0,62
                                            i see some value > 1.5
                                            so it’s not in %
                                            I don’t want to check with the actual CPU usage value, because it’s not for a warning. i think average is a good choice but … my npm library for average not works like I want … humm
