    Extension of MMM-Tools (Bugsounet)
    30 Posts 6 Posters 5.9k Views 6 Watching
      sdetweil @Guest
      @Bugsounet remember there are multiple cores. all at 100% usage is maybe 200%
      • ? Offline
        A Former User
        so … RPI have 4 cores => can display 400% ?
        if it’s that … I have to determinate the number of core (the npm libray can do that)
        and divide the result by the number of cores
        something like that :
        avg = (averageValue * 100) / nbCore
        • ? Offline
          A Former User
          So:
          avg = (averageValue * 100) / nbCore —> don’t working
          I have coded my own method
          I take 10 last values to do an average
          now it’s works and fixed with v2.0.1 :)
            robertybob
            This post is deleted!
              robertybob
              I’ve installed this and everything seems to be working fine :)
                MrDondoT @Guest
                @Bugsounet :thumbs_up: installed and it works great!
                • Sandy2503S Offline
                  Sandy2503
                  @Bugsounet
                  Today i updated the MMM-Tools from my old Version (Sean) to Your New Version 2.01.
                  It Looks great, but i have a Problem.
                  Your Module is in my mirror on Position Bottom Right - but the Information are standing the Center of the Module.
                  Is it possible to move the Information to the right side ?
                  Best Regards,
                  Sandy2503
                  Sorry, for my bad english
                  • ? Offline
                    A Former User
                    @Sandy2503 :
                    • if you consider v1.1.x is sean version, so I did not have to make enough modification since v1.0.0 (like display OS, uptime, optimization) :(
                    • for your problem, i don’t know what do you really want… so try to adjust the css file
                      • you can try in real time modifing with dev console in Elements tab (npm start dev)
                      Sandy2503
                      yes, my english isn`t very well.
                      My be i can show you a picture.
                      I`d like to move the informations to the right border or expand to the whole module position.
                      i think it is possible with the correct css coding …
                      • ? Offline
                        A Former User
                        ah …
                        Force contener size with feature:
                        containerSize feature : unit it’s pixel
                        sample:
                        containerSize: 300,
                        and it will make module wider
                        you can aslo to the same thing with itemSize (for the label section like, os, typ, … rekord)
                        itemSize: for the label section (like, os, typ, … rekord)
                        containerSize: for the result value
                        by default it and autocalc result
                        see the full configuration sample and tunning section for more info of each feature
                        • 3 / 3
