    Extension of MMM-Tools (Bugsounet)
    30 Posts 6 Posters 9.4k Views 6 Watching
      robertybob @Guest
      @Bugsounet I will download it this week and report back ! :D
        A Former User
        no problem, in all case, I release it (It is necessary, otherwise I will never do it!)
        It’s not because I’m releasing that I’m going to drop the project!
        if necessary I will add new request or correct some bug (maybe if happen)
        when i promise something i try to do my best for you all ! :)
          MrDondoT
          @Bugsounet - fyi using the module with MMM-TelegramBot happens that “The usage of CPU is …” over 100% (129 percent), I even got 238 percent
            A Former User
            yes i know, i try an average value of cpu usage, i don’t know about the unit return value … I have X100 value but i think it’s not that
            so disable it (set it to 0), i will see
              A Former User
              so … what is he unit of this:
              load average: 0,97, 0,72, 0,62
              i see some value > 1.5
              so it’s not in %
              I don’t want to check with the actual CPU usage value, because it’s not for a warning. i think average is a good choice but … my npm library for average not works like I want … humm
                sdetweil @Guest
                @Bugsounet remember there are multiple cores. all at 100% usage is maybe 200%
                  A Former User
                  so … RPI have 4 cores => can display 400% ?
                  if it’s that … I have to determinate the number of core (the npm libray can do that)
                  and divide the result by the number of cores
                  something like that :
                  avg = (averageValue * 100) / nbCore
                    A Former User
                    So:
                    avg = (averageValue * 100) / nbCore —> don’t working
                    I have coded my own method
                    I take 10 last values to do an average
                    now it’s works and fixed with v2.0.1 :)
                    M 1 Reply Last reply
                      robertybob
                        robertybob
                        I’ve installed this and everything seems to be working fine :)
                          MrDondoT @Guest
                          @Bugsounet :thumbs_up: installed and it works great!
                          • Sandy2503S
                            Sandy2503
                            @Bugsounet
                            Today i updated the MMM-Tools from my old Version (Sean) to Your New Version 2.01.
                            It Looks great, but i have a Problem.
                            Your Module is in my mirror on Position Bottom Right - but the Information are standing the Center of the Module.
                            Is it possible to move the Information to the right side ?
                            Best Regards,
                            Sandy2503
                            Sorry, for my bad english
                              A Former User
                              @Sandy2503 :
                              • if you consider v1.1.x is sean version, so I did not have to make enough modification since v1.0.0 (like display OS, uptime, optimization) :(
                              • for your problem, i don’t know what do you really want… so try to adjust the css file
                                • you can try in real time modifing with dev console in Elements tab (npm start dev)
                              • Sandy2503S
                                Sandy2503
                                yes, my english isn`t very well.
                                My be i can show you a picture.
                                I`d like to move the informations to the right border or expand to the whole module position.
                                i think it is possible with the correct css coding …
                                  A Former User
                                  ah …
                                  Force contener size with feature:
                                  containerSize feature : unit it’s pixel
                                  sample:
                                  containerSize: 300,
                                  and it will make module wider
                                  you can aslo to the same thing with itemSize (for the label section like, os, typ, … rekord)
                                  itemSize: for the label section (like, os, typ, … rekord)
                                  containerSize: for the result value
                                  by default it and autocalc result
                                  see the full configuration sample and tunning section for more info of each feature
