    Extension of MMM-Tools (Bugsounet)
    30 Posts 6 Posters 9.4k Views 6 Watching
      A Former User
      new change:
      useMagicMirror: true, in UPTIME: {}
      for choice of system uptime (since boot) or magic mirror uptime
        robertybob
        I’m liking these developments, I’m watching with great interest :)
          A Former User
          I finalize ;) and go to master !
          You can try it, if you want
          cd ~/MagicMirror/modules
          git clone -b dev https://github.com/bugsounet/MMM-Tools
          cd MMM-Tools
          npm install
          and read the dev readme for config
          Edit for ALL!
          • Dev is now freeze and waiting for YOUR debug, corrects or additions
          • For me it’s ready for release :)
          • Give me your Feedback !
          • I can display all user connected but … really interesting, i don’t know ??
          • Maybe i have forget something ?
          I do this module for you !
          actually for my usage, it’s ok
          so tell me what do you want to display ;)
            A Former User
            So ?
            Added : MMM-TelegramBot warning (wanted by @lxne)
            Modified translation: it (thx @Cr4z33) , de (thx @lxne)
            Can I Release it ? nothing else to add ?
            R 1 Reply Last reply
              A Former User
              MMM-Tools v2.0.0 is now Released !
              Please Read wiki for new configuration
                robertybob @Guest
                @Bugsounet I will download it this week and report back ! :D
                  A Former User
                  no problem, in all case, I release it (It is necessary, otherwise I will never do it!)
                  It’s not because I’m releasing that I’m going to drop the project!
                  if necessary I will add new request or correct some bug (maybe if happen)
                  when i promise something i try to do my best for you all ! :)
                    MrDondoT
                    @Bugsounet - fyi using the module with MMM-TelegramBot happens that “The usage of CPU is …” over 100% (129 percent), I even got 238 percent
                      A Former User
                      yes i know, i try an average value of cpu usage, i don’t know about the unit return value … I have X100 value but i think it’s not that
                      so disable it (set it to 0), i will see
                        A Former User
                        so … what is he unit of this:
                        load average: 0,97, 0,72, 0,62
                        i see some value > 1.5
                        so it’s not in %
                        I don’t want to check with the actual CPU usage value, because it’s not for a warning. i think average is a good choice but … my npm library for average not works like I want … humm
                          sdetweil @Guest
                          @Bugsounet remember there are multiple cores. all at 100% usage is maybe 200%
                            A Former User
                            so … RPI have 4 cores => can display 400% ?
                            if it’s that … I have to determinate the number of core (the npm libray can do that)
                            and divide the result by the number of cores
                            something like that :
                            avg = (averageValue * 100) / nbCore
                              A Former User
                              So:
                              avg = (averageValue * 100) / nbCore —> don’t working
                              I have coded my own method
                              I take 10 last values to do an average
                              now it’s works and fixed with v2.0.1 :)
                              M 1 Reply Last reply
                                robertybob
                                  robertybob
                                  I’ve installed this and everything seems to be working fine :)
                                    MrDondoT @Guest
                                    @Bugsounet :thumbs_up: installed and it works great!
                                    • Sandy2503S
                                      Sandy2503
                                      @Bugsounet
                                      Today i updated the MMM-Tools from my old Version (Sean) to Your New Version 2.01.
                                      It Looks great, but i have a Problem.
                                      Your Module is in my mirror on Position Bottom Right - but the Information are standing the Center of the Module.
                                      Is it possible to move the Information to the right side ?
                                      Best Regards,
                                      Sandy2503
                                      Sorry, for my bad english
                                        A Former User
                                        @Sandy2503 :
                                        • if you consider v1.1.x is sean version, so I did not have to make enough modification since v1.0.0 (like display OS, uptime, optimization) :(
                                        • for your problem, i don’t know what do you really want… so try to adjust the css file
                                          • you can try in real time modifing with dev console in Elements tab (npm start dev)
                                        • Sandy2503S
                                          Sandy2503
                                          yes, my english isn`t very well.
                                          My be i can show you a picture.
                                          I`d like to move the informations to the right border or expand to the whole module position.
                                          i think it is possible with the correct css coding …
                                            A Former User
                                            ah …
                                            Force contener size with feature:
                                            containerSize feature : unit it’s pixel
                                            sample:
                                            containerSize: 300,
                                            and it will make module wider
                                            you can aslo to the same thing with itemSize (for the label section like, os, typ, … rekord)
                                            itemSize: for the label section (like, os, typ, … rekord)
                                            containerSize: for the result value
                                            by default it and autocalc result
                                            see the full configuration sample and tunning section for more info of each feature
