    Extension of MMM-Tools (Bugsounet)
    30 Posts 6 Posters 8.9k Views 6 Watching
      MiPraSo
      Hi @Bugsounet,
      I’ll be patient and I’ll wait…
      Let me be your alpha and beta tester. :lady_beetle:
      Thanks for your feedback.
        A Former User
        In the last update I add uptime and uptime Record
        now, I be back for some news !
        I changed the code by the new library without sh / bash script and here is the performance:
        [2020-08-11 01:32:07.710] [LOG]    CPU Usage 9
        [2020-08-11 01:32:07.724] [LOG]    CPU Temp: 44
        [2020-08-11 01:32:07.726] [LOG]    Mem Total 7934
        [2020-08-11 01:32:07.726] [LOG]    Mem used 3212
        [2020-08-11 01:32:07.726] [LOG]    Mem % 40
        so very good react ;)
        now i will try:
        • display info about / partition and /home partition (choice of user of course)
        • display ALL used ip adress (and trafic if you want)
        • maybe determinate % of cpu used with MagicMirror (maybe because not tested)
        • what 'is the users connected
        • display RPI version
        Sure, all info will not displayed in config by default. You can enable (or disable) it as you want ;)
        After, the question is :
        I keep the current visual or I change !?
          A Former User
          Hi !
          MMM-Tools fetch all info needed : (tested on my dev platform and not definitive)
          [2020-08-13 17:55:13.191] [LOG]    Send this Status: {
            OS: 'Debian 10 (buster)',
            SYS: 'Core™ i5-3350P',
            NETWORK: [
              enp3s0: { ip: '192.168.0.17', type: 'wired', default: true },
              wlx98ded00d0521: { ip: '192.168.0.193', type: 'wireless', default: false }
            MEMORY: [ total: '7934Mb', used: '2613Mb', percent: '40' ],
            STORAGE: [
              '/': { size: '39.98Go', used: '10.33Go', use: 25.84 },
              '/home': { size: '383.49Go', used: '53.64Go', use: 13.99 },
              '/boot/efi': { size: '96.00Mo', used: '31.57Mo', use: 32.89 },
              '/media/Data': { size: '540.76Go', used: '96.68Go', use: 17.88 }
            CPU: [ temp: '44.0', usage: '23' ],
            UPTIME: '1 jour 17 heures 25 minutes',
            RECORD: '27 jours 18 heures 49 minutes',
            SCREEN_STATUS: 'OFF'
          of course SYS info is the result of CPU type or RPI type
          exemple for a RPI 4:
          SYS: 'Raspberry Pi 4 Model B Rev 1.1'
          RPI 3:
          SYS: 'Raspberry Pi 3 Model B Plus Rev 1.3'
          Now, i will do a new visual for displaying all information received ;)
          Note: If somebody need other information to display, just tell me :)
            A Former User
            This is current information and visual fetched in my dev branch
            Raspberry:
            My dev platform:
            Of course, you can hide, if you want, not needed partitions info.
            if you have multiple network, the default network is represented with a star
            • You can try the dev branch with this command:
            (assumed that v1 is installed)
            cd ~/MagicMirror/modules/MMM-Tools
            git checkout -f dev
            npm install
            • to return to v1:
            git checkout -f master
            npm install
            do not hesitate to give me feedback.
            if any other informations is missing, just tell me :)
              MiPraSo @Guest
              @Bugsounet
              Looks good…
              Here’s some issues:
              1. Is there an example for the config.cfg?
              2. The alignment is now right again, in the old version I was able to adjust it to the left?
              3. How do I get the display wider, in the old version I could adjust it?
              4. How can I change the label, from UPTIME to Laufzeit or *LAN to eth0?
              5. And what are “Go” and “Mo” which should be about “GB” and “MB”?
              Regards,
              Michael
                A Former User
                1. I force all value to display, I don’t really add some feature to personalize actually
                  you can’t actually config:
                  recordUptime: true, to record and display : record uptime
                  partitionExclude : [], fo exclude partition to display
                  sample: partitionExclude : [ "/boot" ], if you don’t want display info about /boot partition
                2. I have to ajust css code
                3. not coded yet (personal feature will be coded in the end)
                4. I’m trying to do a translation file (wait a while ;) )
                  just tell me what value to translate (and translation needed)
                  For Lan to eth0. I have fetch the name info by not displayed actually (because in my dev the WLAN interface have a very very long name)
                  so i have planned a feature for name choice displaying (native or WLAN/LAN)
                5. I will do dual code (actually it’s a test)
                I will be back to you when i have done some totentials change
                  A Former User
                  Yeah !
                  • I have just commit some change on dev branch
                  • I add the new configuration part in Readme
                  • I correct some css code
                  • I correct unit Go to Gb
                  • added translation file (de too)
                    actually supported : en, fr, de (thx to @lxne), id (80% done) and sv (thx to @el97 from github), it (thx to @MrDondoT from github)
                    I can add other language just help me to do the translate file
                  • added telegramBot command /status
                  MagicMirror:
                  TelegamBot:
                    A Former User
                    new change:
                    useMagicMirror: true, in UPTIME: {}
                    for choice of system uptime (since boot) or magic mirror uptime
                      robertybob
                      I’m liking these developments, I’m watching with great interest :)
                        A Former User
                        I finalize ;) and go to master !
                        You can try it, if you want
                        git clone -b dev https://github.com/bugsounet/MMM-Tools
                        cd MMM-Tools
                        npm install
                        and read the dev readme for config
                        Edit for ALL!
                        • Dev is now freeze and waiting for YOUR debug, corrects or additions
                        • For me it’s ready for release :)
                        • Give me your Feedback !
                        • I can display all user connected but … really interesting, i don’t know ??
                        • Maybe i have forget something ?
                        I do this module for you !
                        actually for my usage, it’s ok
                        so tell me what do you want to display ;)
                          A Former User
                          So ?
                          Added : MMM-TelegramBot warning (wanted by @lxne)
                          Modified translation: it (thx @Cr4z33) , de (thx @lxne)
                          Can I Release it ? nothing else to add ?
                            A Former User
                            MMM-Tools v2.0.0 is now Released !
                            Please Read wiki for new configuration
                              robertybob @Guest
                              @Bugsounet I will download it this week and report back ! :D
                                A Former User
                                no problem, in all case, I release it (It is necessary, otherwise I will never do it!)
                                It’s not because I’m releasing that I’m going to drop the project!
                                if necessary I will add new request or correct some bug (maybe if happen)
                                when i promise something i try to do my best for you all ! :)
                                  MrDondoT
                                  @Bugsounet - fyi using the module with MMM-TelegramBot happens that “The usage of CPU is …” over 100% (129 percent), I even got 238 percent
                                    A Former User
                                    yes i know, i try an average value of cpu usage, i don’t know about the unit return value … I have X100 value but i think it’s not that
                                    so disable it (set it to 0), i will see
                                      A Former User
                                      so … what is he unit of this:
                                      load average: 0,97, 0,72, 0,62
                                      i see some value > 1.5
                                      so it’s not in %
                                      I don’t want to check with the actual CPU usage value, because it’s not for a warning. i think average is a good choice but … my npm library for average not works like I want … humm
                                        sdetweil @Guest
                                        @Bugsounet remember there are multiple cores. all at 100% usage is maybe 200%
                                          A Former User
                                          so … RPI have 4 cores => can display 400% ?
                                          if it’s that … I have to determinate the number of core (the npm libray can do that)
                                          and divide the result by the number of cores
                                          something like that :
                                          avg = (averageValue * 100) / nbCore
                                            A Former User
                                            So:
                                            avg = (averageValue * 100) / nbCore —> don’t working
                                            I have coded my own method
                                            I take 10 last values to do an average
                                            now it’s works and fixed with v2.0.1 :)
