    Extension of MMM-Tools (Bugsounet)
    30 Posts 6 Posters 8.9k Views 6 Watching
      sdetweil @MiPraSo
      @MiPraSo in mm, the node_helper is the data ( ip addresses) collector,
      and the modulename.js is the data presenter. See the getDom() routine which builds the html content to be displayed
        A Former User
        Hi, thanks for you feedback ;)
        don’t worry about this !
        I will start the MMM-Tools v2 in a few days !
        I will start this module with new code and a new tool without sh script :)
        of course it will have news functionally like yours
          MiPraSo
          Hi @Bugsounet,
          I’ll be patient and I’ll wait…
          Let me be your alpha and beta tester. :lady_beetle:
          Thanks for your feedback.
            A Former User
            In the last update I add uptime and uptime Record
            now, I be back for some news !
            I changed the code by the new library without sh / bash script and here is the performance:
            [2020-08-11 01:32:07.710] [LOG]    CPU Usage 9
            [2020-08-11 01:32:07.724] [LOG]    CPU Temp: 44
            [2020-08-11 01:32:07.726] [LOG]    Mem Total 7934
            [2020-08-11 01:32:07.726] [LOG]    Mem used 3212
            [2020-08-11 01:32:07.726] [LOG]    Mem % 40
            so very good react ;)
            now i will try:
            • display info about / partition and /home partition (choice of user of course)
            • display ALL used ip adress (and trafic if you want)
            • maybe determinate % of cpu used with MagicMirror (maybe because not tested)
            • what 'is the users connected
            • display RPI version
            Sure, all info will not displayed in config by default. You can enable (or disable) it as you want ;)
            After, the question is :
            I keep the current visual or I change !?
              A Former User
              Hi !
              MMM-Tools fetch all info needed : (tested on my dev platform and not definitive)
              [2020-08-13 17:55:13.191] [LOG]    Send this Status: {
                OS: 'Debian 10 (buster)',
                SYS: 'Core™ i5-3350P',
                NETWORK: [
                  enp3s0: { ip: '192.168.0.17', type: 'wired', default: true },
                  wlx98ded00d0521: { ip: '192.168.0.193', type: 'wireless', default: false }
                MEMORY: [ total: '7934Mb', used: '2613Mb', percent: '40' ],
                STORAGE: [
                  '/': { size: '39.98Go', used: '10.33Go', use: 25.84 },
                  '/home': { size: '383.49Go', used: '53.64Go', use: 13.99 },
                  '/boot/efi': { size: '96.00Mo', used: '31.57Mo', use: 32.89 },
                  '/media/Data': { size: '540.76Go', used: '96.68Go', use: 17.88 }
                CPU: [ temp: '44.0', usage: '23' ],
                UPTIME: '1 jour 17 heures 25 minutes',
                RECORD: '27 jours 18 heures 49 minutes',
                SCREEN_STATUS: 'OFF'
              of course SYS info is the result of CPU type or RPI type
              exemple for a RPI 4:
              SYS: 'Raspberry Pi 4 Model B Rev 1.1'
              RPI 3:
              SYS: 'Raspberry Pi 3 Model B Plus Rev 1.3'
              Now, i will do a new visual for displaying all information received ;)
              Note: If somebody need other information to display, just tell me :)
                A Former User
                This is current information and visual fetched in my dev branch
                Raspberry:
                My dev platform:
                Of course, you can hide, if you want, not needed partitions info.
                if you have multiple network, the default network is represented with a star
                • You can try the dev branch with this command:
                (assumed that v1 is installed)
                cd ~/MagicMirror/modules/MMM-Tools
                git checkout -f dev
                npm install
                • to return to v1:
                git checkout -f master
                npm install
                do not hesitate to give me feedback.
                if any other informations is missing, just tell me :)
                  MiPraSo @Guest
                  @Bugsounet
                  Looks good…
                  Here’s some issues:
                  1. Is there an example for the config.cfg?
                  2. The alignment is now right again, in the old version I was able to adjust it to the left?
                  3. How do I get the display wider, in the old version I could adjust it?
                  4. How can I change the label, from UPTIME to Laufzeit or *LAN to eth0?
                  5. And what are “Go” and “Mo” which should be about “GB” and “MB”?
                  Regards,
                  Michael
                    A Former User
                    1. I force all value to display, I don’t really add some feature to personalize actually
                      you can’t actually config:
                      recordUptime: true, to record and display : record uptime
                      partitionExclude : [], fo exclude partition to display
                      sample: partitionExclude : [ "/boot" ], if you don’t want display info about /boot partition
                    2. I have to ajust css code
                    3. not coded yet (personal feature will be coded in the end)
                    4. I’m trying to do a translation file (wait a while ;) )
                      just tell me what value to translate (and translation needed)
                      For Lan to eth0. I have fetch the name info by not displayed actually (because in my dev the WLAN interface have a very very long name)
                      so i have planned a feature for name choice displaying (native or WLAN/LAN)
                    5. I will do dual code (actually it’s a test)
                    I will be back to you when i have done some totentials change
                      A Former User
                      Yeah !
                      • I have just commit some change on dev branch
                      • I add the new configuration part in Readme
                      • I correct some css code
                      • I correct unit Go to Gb
                      • added translation file (de too)
                        actually supported : en, fr, de (thx to @lxne), id (80% done) and sv (thx to @el97 from github), it (thx to @MrDondoT from github)
                        I can add other language just help me to do the translate file
                      • added telegramBot command /status
                      MagicMirror:
                      TelegamBot:
                        A Former User
                        new change:
                        useMagicMirror: true, in UPTIME: {}
                        for choice of system uptime (since boot) or magic mirror uptime
                          robertybob
                          I’m liking these developments, I’m watching with great interest :)
                            A Former User
                            I finalize ;) and go to master !
                            You can try it, if you want
                            git clone -b dev https://github.com/bugsounet/MMM-Tools
                            cd MMM-Tools
                            npm install
                            and read the dev readme for config
                            Edit for ALL!
                            • Dev is now freeze and waiting for YOUR debug, corrects or additions
                            • For me it’s ready for release :)
                            • Give me your Feedback !
                            • I can display all user connected but … really interesting, i don’t know ??
                            • Maybe i have forget something ?
                            I do this module for you !
                            actually for my usage, it’s ok
                            so tell me what do you want to display ;)
                              A Former User
                              So ?
                              Added : MMM-TelegramBot warning (wanted by @lxne)
                              Modified translation: it (thx @Cr4z33) , de (thx @lxne)
                              Can I Release it ? nothing else to add ?
                                A Former User
                                MMM-Tools v2.0.0 is now Released !
                                Please Read wiki for new configuration
                                  robertybob @Guest
                                  @Bugsounet I will download it this week and report back ! :D
                                    A Former User
                                    no problem, in all case, I release it (It is necessary, otherwise I will never do it!)
                                    It’s not because I’m releasing that I’m going to drop the project!
                                    if necessary I will add new request or correct some bug (maybe if happen)
                                    when i promise something i try to do my best for you all ! :)
                                      MrDondoT
                                      @Bugsounet - fyi using the module with MMM-TelegramBot happens that “The usage of CPU is …” over 100% (129 percent), I even got 238 percent
                                        A Former User
                                        yes i know, i try an average value of cpu usage, i don’t know about the unit return value … I have X100 value but i think it’s not that
                                        so disable it (set it to 0), i will see
                                          A Former User
                                          so … what is he unit of this:
                                          load average: 0,97, 0,72, 0,62
                                          i see some value > 1.5
                                          so it’s not in %
                                          I don’t want to check with the actual CPU usage value, because it’s not for a warning. i think average is a good choice but … my npm library for average not works like I want … humm
                                            sdetweil @Guest
                                            @Bugsounet remember there are multiple cores. all at 100% usage is maybe 200%
