    Extension of MMM-Tools (Bugsounet)
    30 Posts 6 Posters 9.4k Views 6 Watching
      A Former User
      Hi, thanks for you feedback ;)
      don’t worry about this !
      I will start the MMM-Tools v2 in a few days !
      I will start this module with new code and a new tool without sh script :)
      of course it will have news functionally like yours
        MiPraSo
        Hi @Bugsounet,
        I’ll be patient and I’ll wait…
        Let me be your alpha and beta tester. :lady_beetle:
        Thanks for your feedback.
          A Former User
          In the last update I add uptime and uptime Record
          now, I be back for some news !
          I changed the code by the new library without sh / bash script and here is the performance:
          [2020-08-11 01:32:07.710] [LOG]    CPU Usage 9
          [2020-08-11 01:32:07.724] [LOG]    CPU Temp: 44
          [2020-08-11 01:32:07.726] [LOG]    Mem Total 7934
          [2020-08-11 01:32:07.726] [LOG]    Mem used 3212
          [2020-08-11 01:32:07.726] [LOG]    Mem % 40
          so very good react ;)
          now i will try:
          • display info about / partition and /home partition (choice of user of course)
          • display ALL used ip adress (and trafic if you want)
          • maybe determinate % of cpu used with MagicMirror (maybe because not tested)
          • what 'is the users connected
          • display RPI version
          Sure, all info will not displayed in config by default. You can enable (or disable) it as you want ;)
          After, the question is :
          I keep the current visual or I change !?
            A Former User
            Hi !
            MMM-Tools fetch all info needed : (tested on my dev platform and not definitive)
            [2020-08-13 17:55:13.191] [LOG]    Send this Status: {
              OS: 'Debian 10 (buster)',
              SYS: 'Core™ i5-3350P',
              NETWORK: [
                enp3s0: { ip: '192.168.0.17', type: 'wired', default: true },
                wlx98ded00d0521: { ip: '192.168.0.193', type: 'wireless', default: false }
              MEMORY: [ total: '7934Mb', used: '2613Mb', percent: '40' ],
              STORAGE: [
                '/': { size: '39.98Go', used: '10.33Go', use: 25.84 },
                '/home': { size: '383.49Go', used: '53.64Go', use: 13.99 },
                '/boot/efi': { size: '96.00Mo', used: '31.57Mo', use: 32.89 },
                '/media/Data': { size: '540.76Go', used: '96.68Go', use: 17.88 }
              CPU: [ temp: '44.0', usage: '23' ],
              UPTIME: '1 jour 17 heures 25 minutes',
              RECORD: '27 jours 18 heures 49 minutes',
              SCREEN_STATUS: 'OFF'
            of course SYS info is the result of CPU type or RPI type
            exemple for a RPI 4:
            SYS: 'Raspberry Pi 4 Model B Rev 1.1'
            RPI 3:
            SYS: 'Raspberry Pi 3 Model B Plus Rev 1.3'
            Now, i will do a new visual for displaying all information received ;)
            Note: If somebody need other information to display, just tell me :)
              A Former User
              This is current information and visual fetched in my dev branch
              Raspberry:
              My dev platform:
              Of course, you can hide, if you want, not needed partitions info.
              if you have multiple network, the default network is represented with a star
              • You can try the dev branch with this command:
              (assumed that v1 is installed)
              cd ~/MagicMirror/modules/MMM-Tools
              git checkout -f dev
              npm install
              • to return to v1:
              git checkout -f master
              npm install
              do not hesitate to give me feedback.
              if any other informations is missing, just tell me :)
              M 1 Reply Last reply
                MiPraSo @Guest
                @Bugsounet
                Looks good…
                Here’s some issues:
                1. Is there an example for the config.cfg?
                2. The alignment is now right again, in the old version I was able to adjust it to the left?
                3. How do I get the display wider, in the old version I could adjust it?
                4. How can I change the label, from UPTIME to Laufzeit or *LAN to eth0?
                5. And what are “Go” and “Mo” which should be about “GB” and “MB”?
                Regards,
                Michael
                  A Former User
                  1. I force all value to display, I don’t really add some feature to personalize actually
                    you can’t actually config:
                    recordUptime: true, to record and display : record uptime
                    partitionExclude : [], fo exclude partition to display
                    sample: partitionExclude : [ "/boot" ], if you don’t want display info about /boot partition
                  2. I have to ajust css code
                  3. not coded yet (personal feature will be coded in the end)
                  4. I’m trying to do a translation file (wait a while ;) )
                    just tell me what value to translate (and translation needed)
                    For Lan to eth0. I have fetch the name info by not displayed actually (because in my dev the WLAN interface have a very very long name)
                    so i have planned a feature for name choice displaying (native or WLAN/LAN)
                  5. I will do dual code (actually it’s a test)
                  I will be back to you when i have done some totentials change
                    A Former User
                    Yeah !
                    • I have just commit some change on dev branch
                    • I add the new configuration part in Readme
                    • I correct some css code
                    • I correct unit Go to Gb
                    • added translation file (de too)
                      actually supported : en, fr, de (thx to @lxne), id (80% done) and sv (thx to @el97 from github), it (thx to @MrDondoT from github)
                      I can add other language just help me to do the translate file
                    • added telegramBot command /status
                    MagicMirror:
                    TelegamBot:
                      A Former User
                      new change:
                      useMagicMirror: true, in UPTIME: {}
                      for choice of system uptime (since boot) or magic mirror uptime
                        robertybob
                        I’m liking these developments, I’m watching with great interest :)
                          A Former User
                          I finalize ;) and go to master !
                          You can try it, if you want
                          git clone -b dev https://github.com/bugsounet/MMM-Tools
                          cd MMM-Tools
                          npm install
                          and read the dev readme for config
                          Edit for ALL!
                          • Dev is now freeze and waiting for YOUR debug, corrects or additions
                          • For me it’s ready for release :)
                          • Give me your Feedback !
                          • I can display all user connected but … really interesting, i don’t know ??
                          • Maybe i have forget something ?
                          I do this module for you !
                          actually for my usage, it’s ok
                          so tell me what do you want to display ;)
                            A Former User
                            So ?
                            Added : MMM-TelegramBot warning (wanted by @lxne)
                            Modified translation: it (thx @Cr4z33) , de (thx @lxne)
                            Can I Release it ? nothing else to add ?
                            R 1 Reply Last reply
                              A Former User
                              MMM-Tools v2.0.0 is now Released !
                              Please Read wiki for new configuration
                                robertybob @Guest
                                @Bugsounet I will download it this week and report back ! :D
                                  A Former User
                                  no problem, in all case, I release it (It is necessary, otherwise I will never do it!)
                                  It’s not because I’m releasing that I’m going to drop the project!
                                  if necessary I will add new request or correct some bug (maybe if happen)
                                  when i promise something i try to do my best for you all ! :)
                                    MrDondoT
                                    @Bugsounet - fyi using the module with MMM-TelegramBot happens that “The usage of CPU is …” over 100% (129 percent), I even got 238 percent
                                      A Former User
                                      yes i know, i try an average value of cpu usage, i don’t know about the unit return value … I have X100 value but i think it’s not that
                                      so disable it (set it to 0), i will see
                                        A Former User
                                        so … what is he unit of this:
                                        load average: 0,97, 0,72, 0,62
                                        i see some value > 1.5
                                        so it’s not in %
                                        I don’t want to check with the actual CPU usage value, because it’s not for a warning. i think average is a good choice but … my npm library for average not works like I want … humm
                                          sdetweil @Guest
                                          @Bugsounet remember there are multiple cores. all at 100% usage is maybe 200%
                                            A Former User
                                            so … RPI have 4 cores => can display 400% ?
                                            if it’s that … I have to determinate the number of core (the npm libray can do that)
                                            and divide the result by the number of cores
                                            something like that :
                                            avg = (averageValue * 100) / nbCore
