    Extension of MMM-Tools (Bugsounet)
    30 Posts 6 Posters 8.9k Views 6 Watching
      A Former User
      Hi !
      MMM-Tools fetch all info needed : (tested on my dev platform and not definitive)
      [2020-08-13 17:55:13.191] [LOG]    Send this Status: {
        OS: 'Debian 10 (buster)',
        SYS: 'Core™ i5-3350P',
        NETWORK: [
          enp3s0: { ip: '192.168.0.17', type: 'wired', default: true },
          wlx98ded00d0521: { ip: '192.168.0.193', type: 'wireless', default: false }
        MEMORY: [ total: '7934Mb', used: '2613Mb', percent: '40' ],
        STORAGE: [
          '/': { size: '39.98Go', used: '10.33Go', use: 25.84 },
          '/home': { size: '383.49Go', used: '53.64Go', use: 13.99 },
          '/boot/efi': { size: '96.00Mo', used: '31.57Mo', use: 32.89 },
          '/media/Data': { size: '540.76Go', used: '96.68Go', use: 17.88 }
        CPU: [ temp: '44.0', usage: '23' ],
        UPTIME: '1 jour 17 heures 25 minutes',
        RECORD: '27 jours 18 heures 49 minutes',
        SCREEN_STATUS: 'OFF'
      of course SYS info is the result of CPU type or RPI type
      exemple for a RPI 4:
      SYS: 'Raspberry Pi 4 Model B Rev 1.1'
      RPI 3:
      SYS: 'Raspberry Pi 3 Model B Plus Rev 1.3'
      Now, i will do a new visual for displaying all information received ;)
      Note: If somebody need other information to display, just tell me :)
        A Former User
        This is current information and visual fetched in my dev branch
        Raspberry:
        My dev platform:
        Of course, you can hide, if you want, not needed partitions info.
        if you have multiple network, the default network is represented with a star
        • You can try the dev branch with this command:
        (assumed that v1 is installed)
        cd ~/MagicMirror/modules/MMM-Tools
        git checkout -f dev
        npm install
        • to return to v1:
        git checkout -f master
        npm install
        do not hesitate to give me feedback.
        if any other informations is missing, just tell me :)
          MiPraSo @Guest
          @Bugsounet
          Looks good…
          Here’s some issues:
          1. Is there an example for the config.cfg?
          2. The alignment is now right again, in the old version I was able to adjust it to the left?
          3. How do I get the display wider, in the old version I could adjust it?
          4. How can I change the label, from UPTIME to Laufzeit or *LAN to eth0?
          5. And what are “Go” and “Mo” which should be about “GB” and “MB”?
          Regards,
          Michael
            A Former User
            1. I force all value to display, I don’t really add some feature to personalize actually
              you can’t actually config:
              recordUptime: true, to record and display : record uptime
              partitionExclude : [], fo exclude partition to display
              sample: partitionExclude : [ "/boot" ], if you don’t want display info about /boot partition
            2. I have to ajust css code
            3. not coded yet (personal feature will be coded in the end)
            4. I’m trying to do a translation file (wait a while ;) )
              just tell me what value to translate (and translation needed)
              For Lan to eth0. I have fetch the name info by not displayed actually (because in my dev the WLAN interface have a very very long name)
              so i have planned a feature for name choice displaying (native or WLAN/LAN)
            5. I will do dual code (actually it’s a test)
            I will be back to you when i have done some totentials change
              A Former User
              Yeah !
              • I have just commit some change on dev branch
              • I add the new configuration part in Readme
              • I correct some css code
              • I correct unit Go to Gb
              • added translation file (de too)
                actually supported : en, fr, de (thx to @lxne), id (80% done) and sv (thx to @el97 from github), it (thx to @MrDondoT from github)
                I can add other language just help me to do the translate file
              • added telegramBot command /status
              MagicMirror:
              TelegamBot:
                A Former User
                new change:
                useMagicMirror: true, in UPTIME: {}
                for choice of system uptime (since boot) or magic mirror uptime
                  robertybob
                  I’m liking these developments, I’m watching with great interest :)
                    A Former User
                    I finalize ;) and go to master !
                    You can try it, if you want
                    git clone -b dev https://github.com/bugsounet/MMM-Tools
                    cd MMM-Tools
                    npm install
                    and read the dev readme for config
                    Edit for ALL!
                    • Dev is now freeze and waiting for YOUR debug, corrects or additions
                    • For me it’s ready for release :)
                    • Give me your Feedback !
                    • I can display all user connected but … really interesting, i don’t know ??
                    • Maybe i have forget something ?
                    I do this module for you !
                    actually for my usage, it’s ok
                    so tell me what do you want to display ;)
                      A Former User
                      So ?
                      Added : MMM-TelegramBot warning (wanted by @lxne)
                      Modified translation: it (thx @Cr4z33) , de (thx @lxne)
                      Can I Release it ? nothing else to add ?
                        A Former User
                        MMM-Tools v2.0.0 is now Released !
                        Please Read wiki for new configuration
                          robertybob @Guest
                          @Bugsounet I will download it this week and report back ! :D
                            A Former User
                            no problem, in all case, I release it (It is necessary, otherwise I will never do it!)
                            It’s not because I’m releasing that I’m going to drop the project!
                            if necessary I will add new request or correct some bug (maybe if happen)
                            when i promise something i try to do my best for you all ! :)
                              MrDondoT
                              @Bugsounet - fyi using the module with MMM-TelegramBot happens that “The usage of CPU is …” over 100% (129 percent), I even got 238 percent
                                A Former User
                                yes i know, i try an average value of cpu usage, i don’t know about the unit return value … I have X100 value but i think it’s not that
                                so disable it (set it to 0), i will see
                                  A Former User
                                  so … what is he unit of this:
                                  load average: 0,97, 0,72, 0,62
                                  i see some value > 1.5
                                  so it’s not in %
                                  I don’t want to check with the actual CPU usage value, because it’s not for a warning. i think average is a good choice but … my npm library for average not works like I want … humm
                                    sdetweil @Guest
                                    @Bugsounet remember there are multiple cores. all at 100% usage is maybe 200%
                                      A Former User
                                      so … RPI have 4 cores => can display 400% ?
                                      if it’s that … I have to determinate the number of core (the npm libray can do that)
                                      and divide the result by the number of cores
                                      something like that :
                                      avg = (averageValue * 100) / nbCore
                                        A Former User
                                        So:
                                        avg = (averageValue * 100) / nbCore —> don’t working
                                        I have coded my own method
                                        I take 10 last values to do an average
                                        now it’s works and fixed with v2.0.1 :)
                                          robertybob
                                            robertybob
                                            I’ve installed this and everything seems to be working fine :)
