    Extension of MMM-Tools (Bugsounet)
    30 Posts 6 Posters 9.4k Views 6 Watching
      A Former User
      so … what is he unit of this:
      load average: 0,97, 0,72, 0,62
      i see some value > 1.5
      so it’s not in %
      I don’t want to check with the actual CPU usage value, because it’s not for a warning. i think average is a good choice but … my npm library for average not works like I want … humm
        sdetweil @Guest
        @Bugsounet remember there are multiple cores. all at 100% usage is maybe 200%
          A Former User
          so … RPI have 4 cores => can display 400% ?
          if it’s that … I have to determinate the number of core (the npm libray can do that)
          and divide the result by the number of cores
          something like that :
          avg = (averageValue * 100) / nbCore
            A Former User
            So:
            avg = (averageValue * 100) / nbCore —> don’t working
            I have coded my own method
            I take 10 last values to do an average
            now it’s works and fixed with v2.0.1 :)
            M 1 Reply Last reply
              robertybob
                robertybob
                I’ve installed this and everything seems to be working fine :)
                  MrDondoT @Guest
                  @Bugsounet :thumbs_up: installed and it works great!
                  • Sandy2503S
                    Sandy2503
                    @Bugsounet
                    Today i updated the MMM-Tools from my old Version (Sean) to Your New Version 2.01.
                    It Looks great, but i have a Problem.
                    Your Module is in my mirror on Position Bottom Right - but the Information are standing the Center of the Module.
                    Is it possible to move the Information to the right side ?
                    Best Regards,
                    Sandy2503
                    Sorry, for my bad english
                      A Former User
                      @Sandy2503 :
                      • if you consider v1.1.x is sean version, so I did not have to make enough modification since v1.0.0 (like display OS, uptime, optimization) :(
                      • for your problem, i don’t know what do you really want… so try to adjust the css file
                        • you can try in real time modifing with dev console in Elements tab (npm start dev)
                      • Sandy2503S
                        Sandy2503
                        yes, my english isn`t very well.
                        My be i can show you a picture.
                        I`d like to move the informations to the right border or expand to the whole module position.
                        i think it is possible with the correct css coding …
                          A Former User
                          ah …
                          Force contener size with feature:
                          containerSize feature : unit it’s pixel
                          sample:
                          containerSize: 300,
                          and it will make module wider
                          you can aslo to the same thing with itemSize (for the label section like, os, typ, … rekord)
                          itemSize: for the label section (like, os, typ, … rekord)
                          containerSize: for the result value
                          by default it and autocalc result
                          see the full configuration sample and tunning section for more info of each feature
