    Changing IP adresses
    changing ip addresses
    18 Posts 4 Posters 4.1k Views 4 Watching
    • N6NGN Offline
      N6NG @sdetweil
      @sdetweil Ok… I put in the Hostname and it rebooted, but nothing is showing in the right hand corner having to do with Network… I followed the directions and used letters and numbers as directed but it’s still not showing. Is there one more step I missed?
      Dennis
        sdetweil @N6NG
        @N6NG the SSID matches the router, right?
        • N6NGN Offline
          N6NG
          Yes… the one I put in was the one I use for the PC I have in the same room as the MM.
          And I used the same passphrase also…
            sdetweil @N6NG
            @N6NG I do not know how to help more.
            N6NGN 1 Reply Last reply Reply Quote 0
            • N6NGN Offline
              N6NG @sdetweil
              @sdetweil Thank you for what you knew…
              Dennis Jacobson
              • N6NGN Offline
                N6NG
                If I were to reload this chip, what version would you suggest?
                  sdetweil @N6NG
                  @N6NG use buster
                  https://www.raspberrypi.org/downloads/raspberry-pi-os/
                  Raspberry Pi OS (32-bit) with desktop and recommended software
                  • N6NGN Offline
                    N6NG
                    Thank you Sam
                    Dennis
