    Changing IP adresses
    changing ip addresses
    18 Posts 4 Posters 6.2k Views 4 Watching
      sdetweil @N6NG
      @N6NG there should be nothing about the real network in config.js
      address:"0.0.0.0",
      ipWhitelist:[],
      did the SSID of the network change? use the network widget on the raspi desktop, next to the date/time, top right.
      to minimize mm, in case it’s up, alt-spacebar, n
      • N6NGN
        N6NG
        Thanks… I’ll let you know…
        Dennis
        • N6NGN
          N6NG
          That didn’t help… And yes the SSID changed
          Dennis
          • bheplerB
            bhepler Module Developer
            I’m a little confused. Is your Rpi on your wireless network at all? Can you use the web browser on your Pi to pull up a website?
            It sounds like your Pi isn’t playing well with your new router. If you minimize the MM interface and click on the Wifi symbol in the top right of your mirror, you should be able to select the new SSID and enter the password to get onto the network. Did your Wifi network password also change?
            • N6NGN
              N6NG
              No… I can’t connect to any web pages… It just say it can’t find the page I requested…
              Dennis
              • N6NGN
                N6NG
                Doesn’t show the Ssid box in the corner… Just the bluetooth keyboard and the sound speaker and the time. which is incorrect…
                  sdetweil @N6NG
                  @N6NG go to the menu, upper left, then preferences, network
                  • N6NGN
                    N6NG
                    Doesn’t show the Network option … Just the Raspberry Pi Configuration. When I choose; that option, I have an Interfaces option. I pick that one and have several options to enable and disable. One of which is SSH which I enable and it doesn’t do me any good.
                    I’m running the Debian version…
                      sdetweil @N6NG
                      @N6NG open terminal on pi, (ctrl-alt-t) and then sudo raspi-config, network options
                      N6NGN 1 Reply Last reply
                      • N6NGN
                        N6NG @sdetweil
                        @sdetweil Ok… I put in the Hostname and it rebooted, but nothing is showing in the right hand corner having to do with Network… I followed the directions and used letters and numbers as directed but it’s still not showing. Is there one more step I missed?
                        Dennis
                          sdetweil @N6NG
                          @N6NG the SSID matches the router, right?
                          • N6NGN
                            N6NG
                            Yes… the one I put in was the one I use for the PC I have in the same room as the MM.
                            And I used the same passphrase also…
                              sdetweil @N6NG
                              @N6NG I do not know how to help more.
                              • N6NGN
                                N6NG @sdetweil
                                @sdetweil Thank you for what you knew…
                                Dennis Jacobson
                                • N6NGN
                                  N6NG
                                  If I were to reload this chip, what version would you suggest?
                                    sdetweil @N6NG
                                    @N6NG use buster
                                    https://www.raspberrypi.org/downloads/raspberry-pi-os/
                                    Raspberry Pi OS (32-bit) with desktop and recommended software
                                    • N6NGN
                                      N6NG
                                      Thank you Sam
                                      Dennis
