Changing IP adresses
changing ip addresses
18 Posts 4 Posters 4.3k Views 4 Watching
  • N Offline
    N6NG
    I had to change my wireless router. When I dd and rebooted the MagicMirror it can’t see the new wireless system.
    It was working fine with the old routing information when I set it up initially. What do I have to do to get it back on the new address? I tried adding the new address for the new wireless address to the config.js file as described, but it did no good. It still doesn’t see it… Any suggestions?
    Thanks all of you with smarts out there
    Dennis N6NG
    S 1 Reply Last reply Aug 18, 2020, 12:25 AM Reply Quote 0
      sdetweil @N6NG
      @N6NG there should be nothing about the real network in config.js
      address:"0.0.0.0",
      ipWhitelist:[],
      did the SSID of the network change? use the network widget on the raspi desktop, next to the date/time, top right.
      to minimize mm, in case it’s up, alt-spacebar, n
      • N Offline
        N6NG
        Thanks… I’ll let you know…
        Dennis
        • N Offline
          N6NG
          That didn’t help… And yes the SSID changed
          Dennis
            bhepler Module Developer
            I’m a little confused. Is your Rpi on your wireless network at all? Can you use the web browser on your Pi to pull up a website?
            It sounds like your Pi isn’t playing well with your new router. If you minimize the MM interface and click on the Wifi symbol in the top right of your mirror, you should be able to select the new SSID and enter the password to get onto the network. Did your Wifi network password also change?
            • N Offline
              N6NG
              No… I can’t connect to any web pages… It just say it can’t find the page I requested…
              Dennis
              • N Offline
                N6NG
                Doesn’t show the Ssid box in the corner… Just the bluetooth keyboard and the sound speaker and the time. which is incorrect…
                S 1 Reply Last reply Aug 26, 2020, 12:25 AM Reply Quote 0
                  sdetweil @N6NG
                  @N6NG go to the menu, upper left, then preferences, network
                  • N Offline
                    N6NG
                    Doesn’t show the Network option … Just the Raspberry Pi Configuration. When I choose; that option, I have an Interfaces option. I pick that one and have several options to enable and disable. One of which is SSH which I enable and it doesn’t do me any good.
                    I’m running the Debian version…
                    S 1 Reply Last reply Aug 26, 2020, 5:55 PM Reply Quote 0
                      sdetweil @N6NG
                      @N6NG open terminal on pi, (ctrl-alt-t) and then sudo raspi-config, network options
                      N 1 Reply Last reply Aug 26, 2020, 7:06 PM Reply Quote 0
