    Weather forecast only shows 2 lines
    2 Posts 2 Posters 501 Views 3 Watching
    • W Offline
      WillBuden
      I have 2 MagicMirrors set up. One for a friend and my own. Checking the config section for the weather, both are the same. Mine shows the normal 5 lines and fades off at the bottom. My friend’s mirror only shows 2 lines of the forecast. I’ve checked config.js in both and custom.css in both. Not sure where to go look next.
      Thanks,
        sdetweil @WillBuden
        @WillBuden there is a bug. fixed in the develop branch
        how did you install?
        if npm install
        then do
        cd ~/MagicMirror
        git checkout develop
        git pull
        if you used the install script, then do
        cd ~/MagicMirror
        git fetch origin develop:develop
        then restart mm
