    Weather forecast only shows 2 lines
    2 Posts 2 Posters 519 Views 3 Watching
    • W
      WillBuden
      I have 2 MagicMirrors set up. One for a friend and my own. Checking the config section for the weather, both are the same. Mine shows the normal 5 lines and fades off at the bottom. My friend’s mirror only shows 2 lines of the forecast. I’ve checked config.js in both and custom.css in both. Not sure where to go look next.
      Thanks,
        sdetweil @WillBuden
        @WillBuden there is a bug. fixed in the develop branch
        how did you install?
        if npm install
        then do
        git checkout develop
        git pull
        if you used the install script, then do
        git fetch origin develop:develop
        then restart mm
