[Electron] display, MM faded away
Hello,
I finally succeeded tonight in installing MMM-GoogleAssistant bugsounet then my Raspi started to slow down until it blocked, so I rebooted and since then I had to reinstall MMM-DHT-Sensor but above all my MM does not start anymore, appears instead: [Electron] see attached photo, I always have the same screen whether it is with thepm2 restart mmcommand or by closing the [Electron] window which opens automatically or by doing several reboots, there is always this [Electron] window.
I do not want to start all over again … Would there be a diagnostic to launch and publish here to find out where the problem comes from and solve it by a command or reinstall a part that would have scratched?
Thank you for your help.
@RIKKO14 use the pm2 logs command to dump out the logs
pm2 status
pm2 stop 0
pm2 logs --lines=100 -
@sdetweil thanks a lot for the pm2 logs command i found the error and fixed it. It works very well.
Note: if MM is running with pm2. You can use
pm2 logcommand for see logs in real time -
@Bugsounet thanks for the Note.
it’s strange,
sometimes I reboot my Raspberry the device card changes for my microphone plugged in USB, sometimes it is indevice: "plughw: 1",sometimes indevice: "plughw: 2", so I have to change it in myconfig.js -
Yes, i have too this issue sometime ago
now it’s solved with lasted firmware (i think) because i don’t have this problem at now (RPI4)
@Bugsounet I was using a small SD card 8MEG and my logs got too full and kept things from running correctly.
I had to pm2 flush to clear out the logs.
and then restart and it worked.So I got a bigger sd card and have been working on the errors. I found changing the timer in the grove-gestures script got rid of a lot of timeout errors on it’s python script. I also made the news feed refresh less frequently and got less 401 errors from that. Now I can probably go back to the 8gb card. :-)
@kayakbabe if u get 401 from newsfeed, turn off the module don’t let it just post errors to the log
add
disabled:true,after any module name to turn that module off
@sdetweil said in [Electron] display, MM faded away:
disabled:true,
I’m confused… if the module is still in the MagicMirror file and folder structure? is it still executed even if the module is completely commented out of the MagicMirror config.js? or does disabled:true; do the same thing as commenting it out?
@kayakbabe disabled:true does the same as commenting out. and less possible to have an error.
