    [Electron] display, MM faded away
    11 Posts 4 Posters 1.7k Views 4 Watching
      RIKKO14
      it’s strange,
      sometimes I reboot my Raspberry the device card changes for my microphone plugged in USB, sometimes it is in device: "plughw: 1", sometimes in device: "plughw: 2", so I have to change it in my config.js
        A Former User
        Yes, i have too this issue sometime ago
        now it’s solved with lasted firmware (i think) because i don’t have this problem at now (RPI4)
        kayakbabeK 1 Reply Last reply Reply Quote 0
        • kayakbabeK Offline
          kayakbabe @Guest
          @Bugsounet I was using a small SD card 8MEG and my logs got too full and kept things from running correctly.
          I had to pm2 flush to clear out the logs.
          and then restart and it worked.
          So I got a bigger sd card and have been working on the errors. I found changing the timer in the grove-gestures script got rid of a lot of timeout errors on it’s python script. I also made the news feed refresh less frequently and got less 401 errors from that. Now I can probably go back to the 8gb card. :-)
            sdetweil @kayakbabe
            @kayakbabe if u get 401 from newsfeed, turn off the module don’t let it just post errors to the log
            add
            disabled:true,
            after any module name to turn that module off
              kayakbabe @sdetweil
              @sdetweil said in [Electron] display, MM faded away:
              disabled:true,
              I’m confused… if the module is still in the MagicMirror file and folder structure? is it still executed even if the module is completely commented out of the MagicMirror config.js? or does disabled:true; do the same thing as commenting it out?
                sdetweil @kayakbabe
                @kayakbabe disabled:true does the same as commenting out. and less possible to have an error.
