    [Electron] display, MM faded away
    11 Posts 4 Posters 2.1k Views 4 Watching
      sdetweil @RIKKO14
      @RIKKO14 use the pm2 logs command to dump out the logs
      pm2 status
      pm2 stop 0
      pm2 logs --lines=100
        RIKKO14
        @sdetweil thanks a lot for the pm2 logs command i found the error and fixed it. It works very well.
          A Former User
          Note: if MM is running with pm2. You can use pm2 log command for see logs in real time
            RIKKO14 @Guest
            @Bugsounet thanks for the Note.
              RIKKO14
              it’s strange,
              sometimes I reboot my Raspberry the device card changes for my microphone plugged in USB, sometimes it is in device: "plughw: 1", sometimes in device: "plughw: 2", so I have to change it in my config.js
                A Former User
                Yes, i have too this issue sometime ago
                now it’s solved with lasted firmware (i think) because i don’t have this problem at now (RPI4)
                kayakbabeK 1 Reply Last reply Reply Quote 0
                • kayakbabeK Offline
                  kayakbabe @Guest
                  @Bugsounet I was using a small SD card 8MEG and my logs got too full and kept things from running correctly.
                  I had to pm2 flush to clear out the logs.
                  and then restart and it worked.
                  So I got a bigger sd card and have been working on the errors. I found changing the timer in the grove-gestures script got rid of a lot of timeout errors on it’s python script. I also made the news feed refresh less frequently and got less 401 errors from that. Now I can probably go back to the 8gb card. :-)
                    sdetweil @kayakbabe
                    @kayakbabe if u get 401 from newsfeed, turn off the module don’t let it just post errors to the log
                    add
                    disabled:true,
                    after any module name to turn that module off
                      kayakbabe @sdetweil
                      @sdetweil said in [Electron] display, MM faded away:
                      disabled:true,
                      I’m confused… if the module is still in the MagicMirror file and folder structure? is it still executed even if the module is completely commented out of the MagicMirror config.js? or does disabled:true; do the same thing as commenting it out?
                        sdetweil @kayakbabe
                        @kayakbabe disabled:true does the same as commenting out. and less possible to have an error.
