MMM-Google Assistant & MMM-MMM-Assistant2Display
non aucun rapport :)
- Activez le debug mode dans A2D
- pm2 restart 0 -> va redemarrer MagicMirror
- pm2 log -> va vous donner les logs en temps reel
- vous devriez avoir les meme log que vous avez eu pour le reglage, c’est tagger [PIR]
- a vous de calculer selon les dates donnés de value 1 et de value 0 (faire la difference)
Je viens de faire les commandes et j’ai ça :
pi@raspberrypi:~/MagicMirror/modules/MMM-WiFiPassword $ pm2 logs [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option) /home/pi/.pm2/pm2.log last 15 lines: PM2 | 2020-09-01T19:51:58: PM2 log: =============================================================================== PM2 | 2020-09-01T19:51:58: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-09-01T19:51:58: PM2 log: App [mm:0] online PM2 | 2020-09-01T19:57:19: PM2 log: Stopping app:mm id:0 PM2 | 2020-09-01T19:57:19: PM2 log: pid=566 msg=failed to kill - retrying in 100ms PM2 | 2020-09-01T19:57:19: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-09-01T19:57:19: PM2 log: pid=566 msg=process killed PM2 | 2020-09-01T19:57:19: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-09-01T19:57:19: PM2 log: App [mm:0] online PM2 | 2020-09-01T20:04:02: PM2 log: Stopping app:mm id:0 PM2 | 2020-09-01T20:04:03: PM2 log: pid=5525 msg=failed to kill - retrying in 100ms PM2 | 2020-09-01T20:04:03: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT] PM2 | 2020-09-01T20:04:03: PM2 log: pid=5525 msg=process killed PM2 | 2020-09-01T20:04:03: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2020-09-01T20:04:03: PM2 log: App [mm:0] online /home/pi/.pm2/logs/mm-error.log last 15 lines: 0|mm | at DialServer.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/cast/index.js:90:23) 0|mm | at Class.addons (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:5119) 0|mm | at Class.initialize (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:3606) 0|mm | at MD5.cb (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_helper.js:1:847) 0|mm | at MD5.start (/home/pi/MagicMirror/modules/MMM-Assistant2Display/node_modules/@bugsounet/md5/index.js:1:1669) { 0|mm | code: 'EADDRINUSE', 0|mm | errno: 'EADDRINUSE', 0|mm | syscall: 'listen', 0|mm | address: '::', 0|mm | port: 8569 0|mm | } 0|mm | [2020-09-01 20:03:16.390] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [2020-09-01 20:03:16.391] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | [2020-09-01 20:04:14.644] [ERROR] (node:14624) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead. 0|mm | [2020-09-01 20:04:14.648] [ERROR] (node:14624) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead. /home/pi/.pm2/logs/mm-out.log last 15 lines: 0|mm | [2020-09-01 20:04:19.396] [LOG] [NPM] Initialized v0.9.5 0|mm | [2020-09-01 20:04:19.659] [LOG] [ASSISTANT] Google Assistant is initialized. 0|mm | [2020-09-01 20:04:20.411] [LOG] [SCREEN] Display -- Actual: true - Wanted: true 0|mm | [2020-09-01 20:04:21.013] [LOG] [NPM] Details [ 0|mm | { name: '@bugsounet/npmcheck', installed: '0.9.5', latest: '0.9.5' }, 0|mm | { name: '@bugsounet/cast', installed: '1.0.0', latest: '1.0.0' }, 0|mm | { name: '@bugsounet/governor', installed: '1.0.3', latest: '1.0.3' }, 0|mm | { name: '@bugsounet/internet', installed: '1.0.0', latest: '1.0.0' }, 0|mm | { name: '@bugsounet/md5', installed: '1.2.2', latest: '1.2.2' }, 0|mm | { name: '@bugsounet/pir', installed: '1.0.4', latest: '1.0.4' }, 0|mm | { name: '@bugsounet/screen', installed: '1.0.3', latest: '1.0.3' }, 0|mm | { name: '@bugsounet/spotify', installed: '1.0.2', latest: '1.0.2' } 0|mm | ] 0|mm | [2020-09-01 20:04:21.019] [LOG] [NPM] Check... MMM-Assistant2Display 0|mm | [2020-09-01 20:04:21.021] [LOG] [NPM] No update needed for MMM-Assistant2Display 0|mm | [2020-09-01 20:04:54.401] [LOG] 0|mm | [PIR] Sensor read value: 1 0|mm | [2020-09-01 20:04:54.402] [LOG] [PIR] Detected presence (value:1) 0|mm | [2020-09-01 20:04:54.404] [LOG] [SCREEN] Restart. 0|mm | [2020-09-01 20:04:57.217] [LOG] 0|mm | [PIR] Sensor read value: 0 0|mm | [2020-09-01 20:05:10.254] [LOG] 0|mm | [PIR] Sensor read value: 1 0|mm | [2020-09-01 20:05:10.255] [LOG] [PIR] Detected presence (value:1) 0|mm | [2020-09-01 20:05:10.256] [LOG] [SCREEN] Restart. 0|mm | [2020-09-01 20:05:13.138] [LOG] 0|mm | [PIR] Sensor read value: 0 0|mm | [2020-09-01 20:05:43.509] [LOG] 0|mm | [PIR] Sensor read value: 1 0|mm | [2020-09-01 20:05:43.510] [LOG] [PIR] Detected presence (value:1) 0|mm | [2020-09-01 20:05:43.511] [LOG] [SCREEN] Restart. 0|mm | [2020-09-01 20:05:46.659] [LOG] 0|mm | [PIR] Sensor read value: 0 0|mm | [2020-09-01 20:05:53.620] [LOG] 0|mm | [PIR] Sensor read value: 1 0|mm | [2020-09-01 20:05:53.620] [LOG] [PIR] Detected presence (value:1) 0|mm | [2020-09-01 20:05:53.621] [LOG] [SCREEN] Restart. 0|mm | [2020-09-01 20:05:56.432] [LOG] 0|mm | [PIR] Sensor read value: 0 0|mm | [2020-09-01 20:06:05.186] [LOG] 0|mm | [PIR] Sensor read value: 1 0|mm | [2020-09-01 20:06:05.187] [LOG] [PIR] Detected presence (value:1) 0|mm | [2020-09-01 20:06:05.188] [LOG] [SCREEN] Restart. 0|mm | [2020-09-01 20:06:08.004] [LOG] 0|mm | [PIR] Sensor read value: 0 0|mm | [2020-09-01 20:06:13.621] [LOG] 0|mm | [PIR] Sensor read value: 1 0|mm | [2020-09-01 20:06:13.625] [LOG] 0|mm | [PIR] Detected presence (value:1) 0|mm | [2020-09-01 20:06:13.627] [LOG] [SCREEN] Restart. 0|mm | [2020-09-01 20:06:16.438] [LOG] 0|mm | [PIR] Sensor read value: 0 0|mm | [2020-09-01 20:06:22.798] [LOG] 0|mm | [INTERNET] Ping: 14 ms 0|mm | [2020-09-01 20:06:24.435] [LOG] 0|mm | [PIR] Sensor read value: 1 0|mm | [2020-09-01 20:06:24.439] [LOG] 0|mm | [PIR] Detected presence (value:1) 0|mm | [2020-09-01 20:06:24.444] [LOG] 0|mm | [SCREEN] Restart. 0|mm | [2020-09-01 20:06:27.251] [LOG] 0|mm | [PIR] Sensor read value: 0 0|mm | [2020-09-01 20:06:32.163] [LOG] 0|mm | [PIR] Sensor read value: 1 0|mm | [2020-09-01 20:06:32.164] [LOG] [PIR] Detected presence (value:1) 0|mm | [2020-09-01 20:06:32.165] [LOG] [SCREEN] Restart. 0|mm | [2020-09-01 20:06:34.985] [LOG] 0|mm | [PIR] Sensor read value: 0 0|mm | [2020-09-01 20:06:39.836] [LOG] 0|mm | [PIR] Sensor read value: 1 0|mm | [2020-09-01 20:06:39.836] [LOG] [PIR] Detected presence (value:1) 0|mm | [2020-09-01 20:06:39.837] [LOG] [SCREEN] Restart. 0|mm | [2020-09-01 20:06:42.715] [LOG] 0|mm | [PIR] Sensor read value: 0ce qui voudrait dire ?
[2020-09-01 20:06:39.836] [LOG] [PIR] Sensor read value: 1
[2020-09-01 20:06:42.715] [LOG] [PIR] Sensor read value: 042 - 39 --> 3 secs
[AAAA-MM-JJ HH:MM:SS.ms]
Super , merci .
ça me convient comme ça sinon je vais tout dérégler…Merci !
