    2.12 repeating all day calendar events not shown for today, or weather only showing 2 days and missing analog clock numbers
    19 Posts 5 Posters 5.7k Views 5 Watching
    • N Offline
      natrlhy
      Thanks for the extra step!
      For the life of me, it just wont load the forecast…
                              disabled: false,
                              module: "weatherforecast",
                              header: "Weather Forecast",
                                      locationID: "5344157", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                      appid: "myappid",
                                      // maxNumberOfDays: "10",
                                      // fade: "false"
        sdetweil @natrlhy
        @natrlhy open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors usually red text
        and the console where u start mm
        npm start
        or
        pm2 logs --lines=???
        ??? is a number, default 15
        • N Offline
          natrlhy
          Nothing in the dev window…
          pm2 log (20 lines):
          PM2        | 2020-09-23T20:08:10: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2        | 2020-09-23T20:08:10: PM2 log: App [MagicMirror:0] online
          /home/pi/.pm2/logs/MagicMirror-error.log last 20 lines:
          0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:531:27)
          0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:685:19)
          0|MagicMir |     at require (internal/modules/cjs/helpers.js:16:16)
          0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
          0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:786:30)
          0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
          0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:645:32) {
          0|MagicMir |   code: 'MODULE_NOT_FOUND',
          0|MagicMir |   requireStack: [
          0|MagicMir |     '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
          0|MagicMir |     '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
          0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
          0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
          0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
          0|MagicMir |     undefined
          0|MagicMir |   ]
          0|MagicMir | }
          0|MagicMir | [2020-09-23 18:20:11.775] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|MagicMir | [2020-09-23 18:20:11.776] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          /home/pi/.pm2/logs/MagicMirror-out.log last 20 lines:
          0|MagicMir | [2020-09-23 20:08:16.677] [LOG]    Module helper loaded: updatenotification
          0|MagicMir | [2020-09-23 20:08:16.678] [LOG]    No helper found for module: clock.
          0|MagicMir | [2020-09-23 20:08:16.680] [LOG]    No helper found for module: currentweather.
          0|MagicMir | [2020-09-23 20:08:16.682] [LOG]    No helper found for module: weatherforecast.
          0|MagicMir | [2020-09-23 20:08:17.796] [LOG]    Initializing new module helper ...
          0|MagicMir | [2020-09-23 20:08:17.797] [LOG]    Module helper loaded: newsfeed
          0|MagicMir | [2020-09-23 20:08:17.798] [LOG]    All module helpers loaded.
          0|MagicMir | [2020-09-23 20:08:18.142] [LOG]    Starting server on port 8080 ...
          0|MagicMir | [2020-09-23 20:08:18.161] [LOG]    Server started ...
          0|MagicMir | [2020-09-23 20:08:18.162] [LOG]    Connecting socket for: updatenotification
          0|MagicMir | [2020-09-23 20:08:18.164] [LOG]    Connecting socket for: newsfeed
          0|MagicMir | [2020-09-23 20:08:18.165] [LOG]    Starting node helper for: newsfeed
          0|MagicMir | [2020-09-23 20:08:18.166] [LOG]    Sockets connected & modules started ...
          0|MagicMir | [2020-09-23 20:08:18.476] [LOG]    Launching application.
          0|MagicMir | [2020-09-23 20:08:22.215] [LOG]    Create new news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          0|MagicMir | [2020-09-23 20:08:23.231] [INFO]   Newsfeed-Fetcher: Broadcasting 60 items.
          0|MagicMir | [2020-09-23 20:08:29.750] [LOG]    Use existing news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml
          0|MagicMir | [2020-09-23 20:08:29.751] [INFO]   Newsfeed-Fetcher: Broadcasting 60 items.
          0|MagicMir | [2020-09-23 20:08:30.224] [INFO]   Newsfeed-Fetcher: Broadcasting 60 items.
          0|MagicMir | [2020-09-23 20:13:30.985] [INFO]   Newsfeed-Fetcher: Broadcasting 59 items.
          S N 2 Replies Last reply Reply Quote 0
            sdetweil @natrlhy
            @natrlhy u need to do
            cd ~/MagicMirror
            npm install
            because u switched to the develop branch which has a new required library
            • N Offline
              natrlhy @natrlhy
              After I switched to the develop branch, I did cd ~/MagicMirror and ran npm install.
              I refreshed my MM window with inspector and did see this:
              Yet currentweather loads fine with the same appid key…
                sdetweil @natrlhy
                @natrlhy well there is a 401 error on openweather, and a module not found for calendar…
                • N Offline
                  natrlhy
                  pi@teslamate:~/MagicMirror $ npm install
                  > magicmirror@2.13.0-develop install /home/pi/MagicMirror
                  > echo "Installing vendor files ...
                  " && cd vendor && npm install --loglevel=error
                  audited 24 packages in 2.71s
                  1 package is looking for funding
                    run `npm fund` for details
                  found 0 vulnerabilities
                  > magicmirror@2.13.0-develop postinstall /home/pi/MagicMirror
                  > npm run install-fonts && echo "MagicMirror installation finished successfully!
                  > magicmirror@2.13.0-develop install-fonts /home/pi/MagicMirror
                  > echo "Installing fonts ...
                  " && cd fonts && npm install --loglevel=error
                  audited 1 package in 0.981s
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  audited 1124 packages in 60.578s
                  87 packages are looking for funding
                  found 3 low severity vulnerabilities
                    run `npm audit fix` to fix them, or `npm audit` for details
                  • N Offline
                    natrlhy
                    Ok thanks for bearing with me :)
                    I started from scratch again. Generated a new API key from openweathermap, made my changes to the config.js config file. Waited a while since inspector was showing my API was invalid since it was newly generated…
                    Thanks for the help!
                      jani.karna
                      So I have Calendar to show two upcoming birthdays. It is showing them one day too early. Is it the same problem as mentioned earlier? And will the same fix fix them for me?
