    2.12 repeating all day calendar events not shown for today, or weather only showing 2 days and missing analog clock numbers
    19 Posts 5 Posters 6.6k Views 5 Watching
      sdetweil @RIKKO14
      @RIKKO14 ggrrrrrr
      to stash changes, git needs to know WHO did it, in case it gets forgotten. but u are not a developer registered to git
      do
      git checkout package.json
      git checkout develop
        RIKKO14
        WHAOOOO ! it’s ok.
        thanks you much !
        • T Offline
          torte22
          once I switched to the ‘develop’ branch, how can I switch back to ‘master’?
            sdetweil @torte22
            @torte22 git checkout master
            you will lose the fixes from develop of course
            • N Offline
              natrlhy
              I’m trying to get the weather for 2 days to work. I’ve followed the steps on a new install of mm:
              [2020-09-23 18:20:11.758] [ERROR]  Error: Cannot find module 'node-ical'
              Require stack:
              - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
              - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                  at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                  at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                  at Module.require (internal/modules/cjs/loader.js:685:19)
                  at require (internal/modules/cjs/helpers.js:16:16)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                  at Module._compile (internal/modules/cjs/loader.js:786:30)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                  at Module.load (internal/modules/cjs/loader.js:645:32)
              [2020-09-23 18:20:11.762] [ERROR]  Whoops! There was an uncaught exception...
              [2020-09-23 18:20:11.763] [ERROR]  Error: Cannot find module 'node-ical'
              Require stack:
                  at Module.load (internal/modules/cjs/loader.js:645:32) {
                code: 'MODULE_NOT_FOUND',
                requireStack: [
                  '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                  '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                  '/home/pi/MagicMirror/js/app.js',
                  '/home/pi/MagicMirror/js/electron.js',
                  '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                  undefined
              [2020-09-23 18:20:11.775] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [2020-09-23 18:20:11.776] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                sdetweil @natrlhy
                @natrlhy ah, sorry, late change forgot to update instructions… we fixed calendar, but had to use a different library,
                npm install
                will be fixed on next release (Oct 1)
                • N Offline
                  natrlhy
                  Thanks for the extra step!
                  For the life of me, it just wont load the forecast…
                                          disabled: false,
                                          module: "weatherforecast",
                                          header: "Weather Forecast",
                                                  locationID: "5344157", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                                  appid: "myappid",
                                                  // maxNumberOfDays: "10",
                                                  // fade: "false"
                    sdetweil @natrlhy
                    @natrlhy open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors usually red text
                    and the console where u start mm
                    npm start
                    or
                    pm2 logs --lines=???
                    ??? is a number, default 15
                    • N Offline
                      natrlhy
                      Nothing in the dev window…
                      pm2 log (20 lines):
                      PM2        | 2020-09-23T20:08:10: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2020-09-23T20:08:10: PM2 log: App [MagicMirror:0] online
                      /home/pi/.pm2/logs/MagicMirror-error.log last 20 lines:
                      0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                      0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                      0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:685:19)
                      0|MagicMir |     at require (internal/modules/cjs/helpers.js:16:16)
                      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                      0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:786:30)
                      0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                      0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:645:32) {
                      0|MagicMir |   code: 'MODULE_NOT_FOUND',
                      0|MagicMir |   requireStack: [
                      0|MagicMir |     '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                      0|MagicMir |     '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                      0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
                      0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
                      0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                      0|MagicMir |     undefined
                      0|MagicMir |   ]
                      0|MagicMir | }
                      0|MagicMir | [2020-09-23 18:20:11.775] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      0|MagicMir | [2020-09-23 18:20:11.776] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      /home/pi/.pm2/logs/MagicMirror-out.log last 20 lines:
                      0|MagicMir | [2020-09-23 20:08:16.677] [LOG]    Module helper loaded: updatenotification
                      0|MagicMir | [2020-09-23 20:08:16.678] [LOG]    No helper found for module: clock.
                      0|MagicMir | [2020-09-23 20:08:16.680] [LOG]    No helper found for module: currentweather.
                      0|MagicMir | [2020-09-23 20:08:16.682] [LOG]    No helper found for module: weatherforecast.
                      0|MagicMir | [2020-09-23 20:08:17.796] [LOG]    Initializing new module helper ...
                      0|MagicMir | [2020-09-23 20:08:17.797] [LOG]    Module helper loaded: newsfeed
                      0|MagicMir | [2020-09-23 20:08:17.798] [LOG]    All module helpers loaded.
                      0|MagicMir | [2020-09-23 20:08:18.142] [LOG]    Starting server on port 8080 ...
                      0|MagicMir | [2020-09-23 20:08:18.161] [LOG]    Server started ...
                      0|MagicMir | [2020-09-23 20:08:18.162] [LOG]    Connecting socket for: updatenotification
                      0|MagicMir | [2020-09-23 20:08:18.164] [LOG]    Connecting socket for: newsfeed
                      0|MagicMir | [2020-09-23 20:08:18.165] [LOG]    Starting node helper for: newsfeed
                      0|MagicMir | [2020-09-23 20:08:18.166] [LOG]    Sockets connected & modules started ...
                      0|MagicMir | [2020-09-23 20:08:18.476] [LOG]    Launching application.
                      0|MagicMir | [2020-09-23 20:08:22.215] [LOG]    Create new news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                      0|MagicMir | [2020-09-23 20:08:23.231] [INFO]   Newsfeed-Fetcher: Broadcasting 60 items.
                      0|MagicMir | [2020-09-23 20:08:29.750] [LOG]    Use existing news fetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml
                      0|MagicMir | [2020-09-23 20:08:29.751] [INFO]   Newsfeed-Fetcher: Broadcasting 60 items.
                      0|MagicMir | [2020-09-23 20:08:30.224] [INFO]   Newsfeed-Fetcher: Broadcasting 60 items.
                      0|MagicMir | [2020-09-23 20:13:30.985] [INFO]   Newsfeed-Fetcher: Broadcasting 59 items.
                      S N 2 Replies Last reply Reply Quote 0
                        sdetweil @natrlhy
                        @natrlhy u need to do
                        npm install
                        because u switched to the develop branch which has a new required library
                        • N Offline
                          natrlhy @natrlhy
                          After I switched to the develop branch, I did cd ~/MagicMirror and ran npm install.
                          I refreshed my MM window with inspector and did see this:
                          Yet currentweather loads fine with the same appid key…
                            sdetweil @natrlhy
                            @natrlhy well there is a 401 error on openweather, and a module not found for calendar…
                            • N Offline
                              natrlhy
                              pi@teslamate:~/MagicMirror $ npm install
                              > magicmirror@2.13.0-develop install /home/pi/MagicMirror
                              " && cd vendor && npm install --loglevel=error
                              audited 24 packages in 2.71s
                              1 package is looking for funding
                                run `npm fund` for details
                              found 0 vulnerabilities
                              > magicmirror@2.13.0-develop postinstall /home/pi/MagicMirror
                              > npm run install-fonts && echo "MagicMirror installation finished successfully!
                              > magicmirror@2.13.0-develop install-fonts /home/pi/MagicMirror
                              > echo "Installing fonts ...
                              " && cd fonts && npm install --loglevel=error
                              audited 1 package in 0.981s
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                              audited 1124 packages in 60.578s
                              87 packages are looking for funding
                              found 3 low severity vulnerabilities
                                run `npm audit fix` to fix them, or `npm audit` for details
                              • N Offline
                                natrlhy
                                Ok thanks for bearing with me :)
                                I started from scratch again. Generated a new API key from openweathermap, made my changes to the config.js config file. Waited a while since inspector was showing my API was invalid since it was newly generated…
                                Thanks for the help!
                                  jani.karna
                                  So I have Calendar to show two upcoming birthdays. It is showing them one day too early. Is it the same problem as mentioned earlier? And will the same fix fix them for me?
