2.12 repeating all day calendar events not shown for today, or weather only showing 2 days and missing analog clock numbers
19 Posts 5 Posters 4.0k Views 5 Watching
      RIKKO14
      After do this :
      cd ~/MagicMirror/node_modules
      mv ical old_ical
      git clone https://github.com/sdetweil/ical.js.git ical
      cd ical
      npm install
      I do this :
      rm package-lock.json
      git checkout develop
      and here is the answer :
      pi@raspberrypi:~/MagicMirror $ rm package-lock.json
      pi@raspberrypi:~/MagicMirror $ git checkout develop
      error: Vos modifications locales aux fichiers suivants seraient écrasées par l'extraction :
      	package.json
      Veuillez valider ou remiser vos modifications avant de basculer de branche.
      Abandon
      the problem is still there about repeating calendar events :
      my MM shows 2 hours ahead of google calendar
      what can I do ?
      my .ics : https://calendar.google.com/calendar/ical/normandiefinancement14%40gmail.com/private-a887a771c961ca2ba5fa4b44e690aa93/basic.ics
      S 1 Reply Last reply Sep 18, 2020, 1:44 PM Reply Quote 0
        sdetweil @RIKKO14
        @RIKKO14 got them out of order
        do
        git stash
        git stash pop
          RIKKO14
          I do this but the problem sill here after a pm2 restart mm
          pi@raspberrypi:~/MagicMirror $ cd ~/MagicMirror
          pi@raspberrypi:~/MagicMirror $ git stash
          *** Veuillez me dire qui vous êtes.
          Lancez
            git config --global user.email "Vous@exemple.com"
            git config --global user.name "Votre Nom"
          pour régler l'identité par défaut de votre compte.
          Éliminez --global pour ne faire les réglages que dans ce dépôt.
          fatal: impossible de détecter automatiquement l'adresse ('pi@raspberrypi.(none)' trouvé)
          Impossible de sauver l'état courant de l'index
          	package.json
          Abandon
          pi@raspberrypi:~/MagicMirror $ git stash pop
          Aucune entrée de remisage trouvée.
          pi@raspberrypi:~/MagicMirror $ pm2 restart mm
          i think these commands were not carried out
          S 1 Reply Last reply Sep 18, 2020, 1:58 PM Reply Quote 0
            sdetweil @RIKKO14
            @RIKKO14 ggrrrrrr
            to stash changes, git needs to know WHO did it, in case it gets forgotten. but u are not a developer registered to git
            do
            git checkout package.json
              RIKKO14
              WHAOOOO ! it’s ok.
              thanks you much !
              • T Offline
                torte22
                once I switched to the ‘develop’ branch, how can I switch back to ‘master’?
                S 1 Reply Last reply Sep 21, 2020, 12:42 PM Reply Quote 0
                  sdetweil @torte22
                  @torte22 git checkout master
                  you will lose the fixes from develop of course
                  • N Offline
                    natrlhy
                    I’m trying to get the weather for 2 days to work. I’ve followed the steps on a new install of mm:
                    [2020-09-23 18:20:11.758] [ERROR]  Error: Cannot find module 'node-ical'
                    Require stack:
                    - /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                    - /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                        at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                        at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                        at Module.require (internal/modules/cjs/loader.js:685:19)
                        at require (internal/modules/cjs/helpers.js:16:16)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                        at Module._compile (internal/modules/cjs/loader.js:786:30)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                        at Module.load (internal/modules/cjs/loader.js:645:32)
                    [2020-09-23 18:20:11.762] [ERROR]  Whoops! There was an uncaught exception...
                    [2020-09-23 18:20:11.763] [ERROR]  Error: Cannot find module 'node-ical'
                    Require stack:
                        at Module.load (internal/modules/cjs/loader.js:645:32) {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: [
                        '/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js',
                        '/home/pi/MagicMirror/modules/default/calendar/node_helper.js',
                        '/home/pi/MagicMirror/js/app.js',
                        '/home/pi/MagicMirror/js/electron.js',
                        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                        undefined
                    [2020-09-23 18:20:11.775] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [2020-09-23 18:20:11.776] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    S 1 Reply Last reply Sep 24, 2020, 2:40 AM Reply Quote 0
                      sdetweil @natrlhy
                      @natrlhy ah, sorry, late change forgot to update instructions… we fixed calendar, but had to use a different library,
                      npm install
                      will be fixed on next release (Oct 1)
