    MMM Awesome Alexa installing snowboy.
    44 Posts 4 Posters 15.6k Views 4 Watching
      sdetweil @Ameyalgudkar
      @Ameyalgudkar said in MMM Awesome Alexa installing snowboy.:
      I tried the bash c
      looks like you forgot the - in front of c
      bash -c do-install.sh
      and didn’t mark it executable
      chmod +x do-install.sh
      (if u already downloaded the file)
      • G Offline
        gelaw
        @sdetweil Thank you! I finally found my mistake. Yes it does work when your script is followed exactly.
          sdetweil @gelaw
          @gelaw i just made a script out of the steps provided by the author, with one fix for a dependency.
            Ameyalgudkar @sdetweil
            @sdetweil Okay, would gladly like to tell that this did get the errors but it worked even with them. I didn’t knew until now that its fine to get those errors as no one mentions them anywhere in the scripts. Now the one thing is that the alexa only listens once and then stops listening to hotword. My mic is working and I have checked that. Speakers are working, I read somewhere about the electron and Chrome issue not sure if that would be the reason. But if that is then I will try, if that doesn’t work ill ask.
            Thank you for the help and support
            • 3 / 3
