    icon + compliments_plus + How to communicate with default weather module ?
    10 Posts 3 Posters 2.0k Views 2 Watching
    • E Offline
      emrah_asl
      https://github.com/hangorazvan/compliments_plus
      Hi, I love that module but I thought that is beyond on default compliment module.
      I want to use that module to alert weather warns to clients working with current default weather module
      Also I have .svg icon set for each situation. The only thing I want to show image and text depending on current weather.
      For ınstance if it is rainy , the module will show image + rainy text
      How can achieve this ?
      I see these code , but unable to undesrtand who is sending notification.
      notificationReceived: function(notification, payload, sender) { if (notification === “Weather data”) { this.setCurrentWeatherType(payload.data); } },
      • E Offline
        emrah_asl
        How can I connect the Compliments Module with the Weather Module for weather-controlled display of compliments?
        I know there’s a line currentWeatherType: ""in compliments.js but I don’t know what I have to insert in there.
        • ? Offline
          A Former User
          This post is deleted!
            sdetweil @Guest
            @hango the answer to your question in the issue
            notificationReceived: function(notification, payload, sender) { if (notification === "Weather data") { this.setCurrentWeatherType(payload.data); } },
            any module can send this notification. IF the weather module RECEIVES this notification, it expects an object in the payload with an element called ‘data’
            { data:some-value}
            where I guess some_value would be the compliments tags, ‘sunny’, … etc
            ? 1 Reply Last reply Reply Quote 1
            • ? Offline
              A Former User @sdetweil
              • E Offline
                emrah_asl
                Guys, thanks for assisting me but I think the problem in my weather.js, because I guess it is not sending any notification to client side.
                love that module, but unable to find node_helper.js inside of default/weather directory.
                I would like to send notification to client side into this compliment in order to listen and put appropriate text for current weather.
                this compliment module have this
                if (notification === “CURRENTWEATHER_DATA”) {
                console.log(“251”, payload.data);
                But I dont get how to send data from my weather module.
                Sorry for mixed up
                S ? 2 Replies Last reply Reply Quote 0
                  sdetweil @emrah_asl
                  @emrah_asl don’t need node_helper, and can’t use node_helper. it can only handle socketNotifcations
                  this.sendNotification(type, data)
                  from modulename.js
                  • ? Offline
                    A Former User @emrah_asl
                    • E Offline
                      emrah_asl
                      Hi, thanks for assisting me.
                      The problem is I’M not using original weather module, so unable to send notification .
                      I’m using this one :
                      https://github.com/MatthiPi/MMM-DefaultWeatherAnimated
                      module: "weather", //change to weather
                      type: 'current',
                      weatherEndpoint: '/weather',
                      units: 'metric',
                      apiKey: 'X',
                      locationID: Y
                      But unable to figure out how to send notification to current weather objects into this compliment_modules.
                      (where should I write , this code in this module ?) when I try in provider.js, console says "sender should be module"
                      this.sendNotification("CURRENTWEATHER_DATA", {foo: "bar"});
                      MY COMPLIMENT_PLUS Modul compliment_plus.js
                      if (notification === "CURRENTWEATHER_DATA") {
                      console.log("251", payload.data);
                      • ? Offline
                        A Former User
