    icon + compliments_plus + How to communicate with default weather module ?
    10 Posts 3 Posters 1.6k Views 2 Watching
      sdetweil @Guest
      @hango the answer to your question in the issue
      I see these code , but unable to undesrtand who is sending notification.
      notificationReceived: function(notification, payload, sender) { if (notification === "Weather data") { this.setCurrentWeatherType(payload.data); } },
      any module can send this notification. IF the weather module RECEIVES this notification, it expects an object in the payload with an element called ‘data’
      { data:some-value}
      where I guess some_value would be the compliments tags, ‘sunny’, … etc
      ? 1 Reply Last reply Reply Quote 1
        A Former User @sdetweil
        • E Offline
          emrah_asl
          Guys, thanks for assisting me but I think the problem in my weather.js, because I guess it is not sending any notification to client side.
          love that module, but unable to find node_helper.js inside of default/weather directory.
          I would like to send notification to client side into this compliment in order to listen and put appropriate text for current weather.
          this compliment module have this
          if (notification === “CURRENTWEATHER_DATA”) {
          console.log(“251”, payload.data);
          But I dont get how to send data from my weather module.
          Sorry for mixed up
          S ? 2 Replies Last reply Reply Quote 0
            sdetweil @emrah_asl
            @emrah_asl don’t need node_helper, and can’t use node_helper. it can only handle socketNotifcations
            this.sendNotification(type, data)
            from modulename.js
              A Former User @emrah_asl
              • E Offline
                emrah_asl
                Hi, thanks for assisting me.
                The problem is I’M not using original weather module, so unable to send notification .
                I’m using this one :
                https://github.com/MatthiPi/MMM-DefaultWeatherAnimated
                module: "weather", //change to weather
                type: 'current',
                weatherEndpoint: '/weather',
                units: 'metric',
                apiKey: 'X',
                locationID: Y
                But unable to figure out how to send notification to current weather objects into this compliment_modules.
                (where should I write , this code in this module ?) when I try in provider.js, console says "sender should be module"
                this.sendNotification("CURRENTWEATHER_DATA", {foo: "bar"});
                MY COMPLIMENT_PLUS Modul compliment_plus.js
                if (notification === "CURRENTWEATHER_DATA") {
                console.log("251", payload.data);
                  A Former User
