    How to call my cloud base magic mirror from raspberry pi 4
    7 Posts 2 Posters 1.8k Views 2 Watching
    • E Offline
      emrah_asl
      Hi Guys, Finally I have created my alpha version of magic mirror and ready for run.
      I uploaded all my files into my private server (like amazon) and I have web link to run this.
      For Instances my magic mirror link will be: https://emrahaslan.magicmirror.com
      I don’t want to put my code on raspbbery sd disk, the only thing I want to call this link Inside electron.js web view via raspberry side, But It should run original magic mirror software (autorun when restart vs)
      do I need install magic mirror again for client side ? thanks for help for assisting me step by step.
        sdetweil @emrah_asl
        @emrah_asl just open chromium browser to your server.
        see the last few lines of the script I built for pi0 which needs to use chromium. see
        https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh
        line 76
        • E Offline
          emrah_asl
          I see the file but I’m not familiar to use it. Coudl you please help me ?
          I did these steps :
          I am trying to do a client only build on a Pi. I want to request the basic instructions please.
          Does this sound right my steps.
          1 - Install Raspbian from web site and write in sd disk
          2 - open raspberry
          3- open terminal
          git clone https://github.com/MichMich/MagicMirror
          4- cd ~/MagicMirror
          npm install
          5- (NOT NPM START)
          node clientonly --address https://emrahaslan.magicmirror.com --port 8080
          It’s works but,
          Will this do anything to prevent screensaver or powersaver mode etc?
          when restart rpi , default local magic mirror is starting :(
            sdetweil @emrah_asl
            @emrah_asl again, u don’t need all that
            one bash file with the one command, line 76 of my script,
            started by pm2 on boot
            pm2 start your_scriptname
            pm2 save
            and use the screensaver script from my site to turn off screen saver
            • E Offline
              emrah_asl
              Hi Again,
              1- I uninstalled magic mirror from my spi4.
              2- I downloaded run-start.sh all your content and copy paste ( edited 76th line sections acording my URL.
              3- and created startupPega.sh and located it my rpi root folder.
              4- Then I opened terminal and write
              pm2 start mm.sh
              then pm2 save
              Should I see my mirror on page browser ? Nothing happened. what I need for my next steps to run this automatically when restart rpi ?
                sdetweil @emrah_asl
                @emrah_asl see my text messages
                • E Offline
                  emrah_asl
                  Hello thank you ver much for your practive solution.
                  I learned how to batch files runs.
