    MMM-Calendar always shows 23:59 if showEndTime: True
    51 Posts 4 Posters 21.5k Views 3 Watching
      SwissChemist
      Hello,
      I don’t have much experience in software development, but so far I have been quite successful in setting up my MagicMirror.
      Nevertheless I am struggling with the calender module with the following two issues:
      1. showEnd: true
        Although I managed to get the right start time with the help of “Timeshift calendar issue / Recurring Google Calendar events for times when UTC date differ from local date appear at wrong time in MM #1798”, I can only see 23:59 for the end time for recurring events on my iCalendar. (With non recurring events, the end time is correct!)
        All the examples and maybe also most testers set the parameter showEnd to ‘false’, then this problem cannot be seen.
      2. For 3-weekly events (whole day), the timeshift problem seems to be unsolved?! In this case I can see a wrong date. With weekly and biweekly events (whole day) everything works fine!
      Can anybody confirm if these issues are still present, or has anybody an idea, what might be wrong with my files?
      			header: "Familie",
      				maximumEntries: 25,
      				maximumNumberOfDays: 365,
      				showLocation: false,
      				maxTitleLength: 25,
      				maxLocationTitleLength: 25,
      				wrapEvents: true,
      				wrapLocationEvents: false,
      				maxTitleLines: 3,
      				maxEventTitleLines: 3,
      				fetchInterval: 300000, //default: 300000
      				animationSpeed: 2000,
      				fade: true,
      				fadePoint: 0.25,
      				displayRepeatingCountTitle: true,
      				dateFormat: "MMM Do",
      				dateEndFormat: "HH:mm",
      				showEnd: true,
      				fullyDayEventDateFormat: "MMM Do",
      				timeFormat: "absolute",
      				getRelative: 6,
      				urgency: 1,
      				broadcastEvents: true,
      				hidePrivate: false,
      				sliceMultiDayEvents: false,
      				nextDaysRelative: true,
      						symbol: "home",
      						url: "webcal://..."
      Thanks very much for your support!
        sdetweil @SwissChemist
        @SwissChemist see the calendar temp fixes at the top of the troubleshooting section
          SwissChemist
          Dear Sam,
          I have exactly done what is written in your instructions.
          The start date is shown correctly, but there are two issues left:
          1. with ‘showEnd: True’ I can see 23:59 for recurring events (not whole day) on my calendar. (With non recurring events, the end time is correct!)
          2. some dates for recurring events (whole day) are wrong.
          I have prepared an ics-file and a screenshot of my MagicMirror Monitor for comparison.
          The following dates are wrong:
          3-weekly whole day - 22.Okt should be: 21.Okt
          Weekly whole day - 26.Okt should be: 27.Okt
          2-weekly whole day - 27.Okt should be: 28.Okt
          Monthly whole day - 1.Nov should be 2.Nov
          Weekly whole day - 2.Nov should be 3.Nov
          Weekly whole day - 9.Nov should be 10.Nov
          2-weekly whole day - 10.Nov should be 11.Nov
          I have defined a test calendar, ich which all weeklys are planned for the same day, all 2-weeklys are planned for the same day, all 3-weeklys are planned for the same day. So you can easily see if these dates differ, there is a mistake…
          Files and a MagicMirror picture are attached.
          ![0_1601321066459_MagicMirror.JPG](Uploading 100%)
          [0_1601321084756_myCalendar](Uploading 100%)
            @SwissChemist please see my cat message…
            i assume you are gmt+ something…
            there is a newly found bug in the repeating rule parser, which I am working on. but it might be a while…
            if the normal time of the event is not exceeded by your tz offset then the event date is (in gmt) the prior day.
            then the rule calculates, and gets the current day, and the jams the prior to midnight time onto the event, now it is 24 hours later…
            at the time the calculation and adjustment is done, the rule processor doesn’t know the original effect of the timezone offset
              SwissChemist
              You are right, now in summer, we are GMT+1, in winter it’s GMT+2…
                @SwissChemist
                no the one I am fighting from Australia
                meeting at 09/28/20, 08:30
                utc is 09/27/20, 22:30
                rule detemines today is valid DATE
                takes todays date 09/28, with yesterdays time 22:30
                oops…
                  @sdetweil so, your 1st entry is confusing… label is
                  SUMMARY:Monthly 17-18
                  but the cal entry says
                  DTSTART;TZID=Europe/Zurich:20201002T170000, Oct 02, 1700 local, 1500 utz
                    sdetweil
                    also, showEnd is a pain… technically the clock is day:00:00 to day 23:59 as 23:59+1 is 24:00/00:00 which is the next day
                    so, what do you think we should be showing there…
                      @SwissChemist want to try a fix for me…
                      edited: changed added line
                      edit the ~/MagicMirror/modules/default/calendar/calendarfetcher.js
                      find this (approx line 240) and add the one line listed below
                      						// Loop through the set of date entries to see which recurrences should be added to our event list.
                      						for (let d in dates) {
                      							const date = dates[d];
                      							// ical.js started returning recurrences and exdates as ISOStrings without time information.
                      							// .toISOString().substring(0,10) is the method they use to calculate keys, so we'll do the same
                      							// (see https://github.com/peterbraden/ical.js/pull/84 )
                      							const dateKey = date.toISOString().substring(0, 10);
                      							let curEvent = event;
                      							let showRecurrence = true;
                      							let duration = 0;
                      							startDate = moment(date);
                      							duration = parseInt(moment(curEvent.end).format("x")) - parseInt(moment(curEvent.start).format("x")) // --- add this line
                      in your timezone (mine is Sep 28, 17:15)
                        SwissChemist
                        Hello Sam,
                        thanks very much for your great support.
                        Good news is that the endTime issue is solved now!
                        Nevertheless with recurring whole day events, the following entries are not correct yet:
                        3-weekly 13-14 is completely missing (should be 1.Okt)
                        Starting with the 3-weekly whole day 22.Okt (should be 21.Okt), every following ‘whole day meeting’ is shown one day too late.
                        You can easily see that even on your picture, as e.g. the 3-weekly whole day and the 3-weekly 13-14 should always take place at the same date.
                        Even on your picture this is not the case… monthly whole day is shown in 3 days, monthly 17-18 is shown in 4 days.
                        Once more, thanks for your great support so far!
                        ![0_1601412306493_MagicMirror_200929.JPG](Uploading 100%)
                          sdetweil
                          yeh, that whole day thing… the spec says its whole day in the timezone where the computer is.
                          but the ical converter still adjusts it to UTC. (all parsed events are in UTC)
                          can’t be cause u asked for WEdnesdays
                          BEGIN:VEVENT
                          CREATED:20200928T173050Z
                          DTEND;VALUE=DATE:20201002
                          DTSTAMP:20200928T182733Z
                          DTSTART;VALUE=DATE:20201001
                          LAST-MODIFIED:20200928T182732Z
                          RRULE:FREQ=WEEKLY;INTERVAL=3;BYDAY=WE  < ----
                          SEQUENCE:0
                          SUMMARY:3-weekly whole day
                          UID:E2C82F47-1E0F-4FD0-93C4-746B2D53488B
                          URL;VALUE=URI:
                          END:VEVENT
                          so , this repeating event might start on Oct 1, but thats a thursday, so will not be shown
                          but later, Starting with the 3-weekly whole day 22.Okt (should be 21.Okt),
                          starts on 21+1 days from today 00:00:00 Oct 21, and ends on Oct 22
                          this is a fix in the ical parser… so, it will take time to get out…
                            sdetweil
                            can we try another quick fix?
                            in calendar.js
                            				// Define second, minute, hour, and day variables
                            				var oneSecond = 1000; // 1,000 milliseconds
                            				var oneMinute = oneSecond * 60;
                            				var oneHour = oneMinute * 60;
                            				var oneDay = oneHour * 24;
                            				if (event.fullDayEvent) {
                            					//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 one the next day
                            					//event.endDate -= oneSecond;   < ---- comment out this one line
                              SwissChemist @sdetweil
                              maybe you expected already that now the endTime of each whole day event is shown one day too late. Without that fix, it has been correct.
                              Regarding the ‘3-weekly whole day’ you gave me a perfect hint: As it is a user configured interval, you have to take care that begin of the event and day of the week you select as interval correspond. So if you configure it wrong, corresponding event will obviously not be shown, as you explained perfectly from your code analysis…
                                I would not mind to see 23:59 as end of a whole day event, but it would also be fine for me to see the day where it starts again…
                                  @SwissChemist finding an acceptable “end” marker for “full day” event is challenging.
                                  it certainly ends when the next day starts.
                                    @SwissChemist can u look at this, your cal, in your timezone, 2.13 no modifications
                                    showEnd:true,
                                    maximumEntries:25,
                                      SwissChemist
                                      It’s getting better and better, great!
                                      The only event, which is not correct yet, ist the 3-weekly 13-14. This should be in 21 days (Oct 22nd), exactly like the 3-weekly whole day. The following ones could be better controlled in an absolute time format…
                                        @SwissChemist no… that cal entry says wednesdays, so the 21st, rule wins on exact days, start/end win on time
                                        BEGIN:VEVENT
                                        CREATED:20200928T173453Z
                                        DTEND;TZID=Europe/Zurich:20201001T140000
                                        DTSTAMP:20200928T182743Z
                                        DTSTART;TZID=Europe/Zurich:20201001T130000
                                        LAST-MODIFIED:20200928T182742Z
                                        RRULE:FREQ=WEEKLY;INTERVAL=3;BYDAY=WE  < -------
                                        SEQUENCE:0
                                        SUMMARY:3-weekly 13-14
                                        UID:A7C8DBD0-0AA9-468B-A3F8-A5F97B797C11
                                        URL;VALUE=URI:
                                        END:VEVENT
                                          SwissChemist
                                          Ok, then it’s my error again. In the meantime I have corrected my calendar entry. Would you need a new calenendar export, or would you like to send me your fix to test it here?
                                            @SwissChemist install/upgrade to 2.13, should fix it
                                            I changed cal entry to TH, now shows 21 days, on the 22nd
                                            • 1 / 3
