    MMM-Calendar always shows 23:59 if showEndTime: True
    51 Posts 4 Posters 17.6k Views 3 Watching
      SwissChemist
      Thanks very much for your help! I highly appreciate it!
        sdetweil @SwissChemist
        @SwissChemist my pleasure… here is how I config MM to use your file
        (note my mm is on a different port)
                    url: "http://localhost:8090/modules/default/calendar/school-timetable.ics"
          SwissChemist
          Thanks for the example. Looks like a next project for me… :thumbs_up:
            @SwissChemist
            could look something like this
            #!/bin/bash
            fn=somecal.ics
            while true
              do
                  # get the file from server
                  curl -sL  url_of_remote_ics  >$fn
                  # remove the trailing byday=??(end of line), file inline, so changed
                  sed -i -e "s/;BYDAY=.*$//g" $fn
                 # copy the modified file to the calendar folder
                  cp $fn ~/MagicMirror/modules/default/calendar
                 # sleep til next cycle
                  sleep ??? (seconds til next curl)
               done
            have to make this executable with chmod +x script_filename
            then
            pm2 start script_filename
            pm2 save
            if you use a json config file ui can give a pretty name of the script… see the installers/pm2_magicmirror.json
            pm2 start jsonfile
            pm2 save
              @SwissChemist I submitted this issue to the RRULE repo
              https://github.com/jakubroztocil/rrule/issues/426
                SwissChemist @sdetweil
                Wow, thank you so much for your great support!
                  @sdetweil This morning we switched from DST to STD time. No issue at all with the calendar, everything works fine!
                  Again, thanks very much for your support!
                    @SwissChemist nice, thanks for the update
                    • ? Offline
                      A Former User
                      This post is deleted!
                      • ? Offline
                        A Former User
                        @hango: yes that why i have planned to coding mine…
                        Calendar default module is really so bugy for me …
                        sample :
                        0|MagicMirror  | [2020-10-25 21:17:41.162] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXX.ics
                        0|MagicMirror  | [2020-10-25 21:17:41.164] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
                        0|MagicMirror  | [2020-10-25 21:17:41.715] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
                        and some timethere is 3 broadcasts … result 2 or 3 updates on mirror
                        I don’t know really what they do with this modules… and I will NOT correct it !
                        In all case, it’s horrible
                        • 6
                        • 5 / 6
