    MMM-Calendar always shows 23:59 if showEndTime: True
    51 Posts 4 Posters 20.2k Views 3 Watching
      sdetweil @SwissChemist
      @SwissChemist like I said, bug in the repeating rule processor, RRULE. not our code.
      Remove the byday, or the second day
        SwissChemist @sdetweil
        Sorry for asking:
        If I would import a calendar file from a text file, it would be easy to do the correction (change DTEND or remove BYDAY) in any text editor.
        But how to proceed if I directly import data from *.ics link? Is there any ‘hack’ I could apply?
        Thanks very much for your patience… All other data are really great now! And somehow I rely on a 3-weekly whole day, as we use to have 3-week iterations in our SCRUM process…
          @SwissChemist you could create a batch script, run off cron, or started w pm2 (and use sleep to wait)
          curl to download the ics,
          sed to fix the file,
          and put it into the calendar module folder, and
          config mm to use it from there
            SwissChemist
            Thanks very much for your help! I highly appreciate it!
              @SwissChemist my pleasure… here is how I config MM to use your file
              (note my mm is on a different port)
                          url: "http://localhost:8090/modules/default/calendar/school-timetable.ics"
                SwissChemist
                Thanks for the example. Looks like a next project for me… :thumbs_up:
                  @SwissChemist
                  could look something like this
                  #!/bin/bash
                  fn=somecal.ics
                  while true
                    do
                        # get the file from server
                        curl -sL  url_of_remote_ics  >$fn
                        # remove the trailing byday=??(end of line), file inline, so changed
                        sed -i -e "s/;BYDAY=.*$//g" $fn
                       # copy the modified file to the calendar folder
                        cp $fn ~/MagicMirror/modules/default/calendar
                       # sleep til next cycle
                        sleep ??? (seconds til next curl)
                     done
                  have to make this executable with chmod +x script_filename
                  then
                  pm2 start script_filename
                  pm2 save
                  if you use a json config file ui can give a pretty name of the script… see the installers/pm2_magicmirror.json
                  pm2 start jsonfile
                  pm2 save
                    @SwissChemist I submitted this issue to the RRULE repo
                    https://github.com/jakubroztocil/rrule/issues/426
                      Wow, thank you so much for your great support!
                        @sdetweil This morning we switched from DST to STD time. No issue at all with the calendar, everything works fine!
                        Again, thanks very much for your support!
                          @SwissChemist nice, thanks for the update
                            A Former User
                              A Former User
                              @hango: yes that why i have planned to coding mine…
                              Calendar default module is really so bugy for me …
                              sample :
                              0|MagicMirror  | [2020-10-25 21:17:41.162] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXX.ics
                              0|MagicMirror  | [2020-10-25 21:17:41.164] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
                              0|MagicMirror  | [2020-10-25 21:17:41.715] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
                              and some timethere is 3 broadcasts … result 2 or 3 updates on mirror
                              I don’t know really what they do with this modules… and I will NOT correct it !
                              In all case, it’s horrible
                                sdetweil @Guest
                                @hango have fun. there are 3 libraries below the mm code. all broken or in disagreement over the format of the date and time. and windows is a whole nother mess
                                why I work my a… off for you … I begin to wonder.
                                2.11 might work for you but it doesn’t for others. and I didn’t start the changes.
                                • 3 / 3
