    MMM-Calendar always shows 23:59 if showEndTime: True
    51 Posts 4 Posters 21.3k Views 3 Watching
      sdetweil @SwissChemist
      @SwissChemist yeh, that 3-weekly whole day event seems to cause a problem in the rule handler…
      for THAT rule, it returns the repeating day as the 1st of the 2, (the last of the 2 for the others)
      but if u take off the ;BYDAY=TH
      is works properly… (and gives the thrusday date)
      so, some bug in the rrule module… (not our code)
      that is also the only weekly whole day rule you have which has a ByDay set.
        SwissChemist @sdetweil
        As I wondered if the format of an 3-weekly event in ical has an issue, I set up a 3-weekly event in Google calendar and compared the files:
        BEGIN:VEVENT
        DTSTART;VALUE=DATE:20201005
        DTEND;VALUE=DATE:20201006
        RRULE:FREQ=WEEKLY;INTERVAL=3;BYDAY=MO
        DTSTAMP:20201005T195008Z
        UID:835F136F-35A4-44C6-AA16-481F02E5A2D1
        CREATED:20201005T120626Z
        DESCRIPTION:
        LAST-MODIFIED:20201005T120626Z
        SEQUENCE:0
        STATUS:CONFIRMED
        SUMMARY:3-weekly whole day test
        TRANSP:OPAQUE
        END:VEVENT
        Event has been set to 5th of October and DTEND is also one day later than DTSTART for a whole-day-event and it also shows a BYDAY, that means it’s absolutely identical to the ical file…
          @SwissChemist like I said, bug in the repeating rule processor, RRULE. not our code.
          Remove the byday, or the second day
            Sorry for asking:
            If I would import a calendar file from a text file, it would be easy to do the correction (change DTEND or remove BYDAY) in any text editor.
            But how to proceed if I directly import data from *.ics link? Is there any ‘hack’ I could apply?
            Thanks very much for your patience… All other data are really great now! And somehow I rely on a 3-weekly whole day, as we use to have 3-week iterations in our SCRUM process…
              @SwissChemist you could create a batch script, run off cron, or started w pm2 (and use sleep to wait)
              curl to download the ics,
              sed to fix the file,
              and put it into the calendar module folder, and
              config mm to use it from there
                SwissChemist
                Thanks very much for your help! I highly appreciate it!
                  @SwissChemist my pleasure… here is how I config MM to use your file
                  (note my mm is on a different port)
                              url: "http://localhost:8090/modules/default/calendar/school-timetable.ics"
                    SwissChemist
                    Thanks for the example. Looks like a next project for me… :thumbs_up:
                      @SwissChemist
                      could look something like this
                      #!/bin/bash
                      fn=somecal.ics
                      while true
                        do
                            # get the file from server
                            curl -sL  url_of_remote_ics  >$fn
                            # remove the trailing byday=??(end of line), file inline, so changed
                            sed -i -e "s/;BYDAY=.*$//g" $fn
                           # copy the modified file to the calendar folder
                            cp $fn ~/MagicMirror/modules/default/calendar
                           # sleep til next cycle
                            sleep ??? (seconds til next curl)
                         done
                      have to make this executable with chmod +x script_filename
                      then
                      pm2 start script_filename
                      pm2 save
                      if you use a json config file ui can give a pretty name of the script… see the installers/pm2_magicmirror.json
                      pm2 start jsonfile
                      pm2 save
                        @SwissChemist I submitted this issue to the RRULE repo
                        https://github.com/jakubroztocil/rrule/issues/426
                          Wow, thank you so much for your great support!
                            @sdetweil This morning we switched from DST to STD time. No issue at all with the calendar, everything works fine!
                            Again, thanks very much for your support!
                              @SwissChemist nice, thanks for the update
                                A Former User
                                  A Former User
                                  @hango: yes that why i have planned to coding mine…
                                  Calendar default module is really so bugy for me …
                                  sample :
                                  0|MagicMirror  | [2020-10-25 21:17:41.162] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXX.ics
                                  0|MagicMirror  | [2020-10-25 21:17:41.164] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
                                  0|MagicMirror  | [2020-10-25 21:17:41.715] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
                                  and some timethere is 3 broadcasts … result 2 or 3 updates on mirror
                                  I don’t know really what they do with this modules… and I will NOT correct it !
                                  In all case, it’s horrible
                                    sdetweil @Guest
                                    @hango have fun. there are 3 libraries below the mm code. all broken or in disagreement over the format of the date and time. and windows is a whole nother mess
                                    why I work my a… off for you … I begin to wonder.
                                    2.11 might work for you but it doesn’t for others. and I didn’t start the changes.
                                    • 3 / 3
